Old 11-12-2005, 04:53 AM   #26
71Dragtruck
71Dragtruck's Avatar
Re: Coil Overs
Originally Posted by BowTieMan
Do you think coil overs will help my traction alot? I was out at the track tonight with my truck and one run was a 20 because I spun through first and all through second. And every run I had to baby it off the line and the best run was a 16.95 with some sliping.
What are you running for tires? Coil over setup, 4-link's etc. all help alot with weight transfer, but without a good set of drag tires you aren't going to hook. I've seen trucks at the track with stock suspension and a set of slicks hook up and run low 13's hi 12's, nothing fancy, stripped down and slicks. I run a 4-link and coil overs and street tires still don't stand a chance, I run QT Pro's and don't spin at all at the track, on the street is a different story.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 11-12-2005, 11:27 AM   #27
bigjimzlll
bigjimzlll's Avatar
Re: Coil Overs
I run a stock suspension(with lowering springs) and run 10.90's
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 12-20-2005, 01:44 AM   #28
Deckhand
Re: Coil Overs
I just recently aquired a 68 pickup and will redo everything from the ground up. Will that qa1/coil over setup be able to provide 6" of drop?
I want to do a 4/6 but would like to have some adjustablity for a good ride height as well as quality.
Any suggestions? thanks!
Deckhand is offline   Reply With Quote
Thread Tools
Display Modes
