Old 11-28-2005, 08:23 PM   #26
BigSky71
LAIDOUT
BigSky71's Avatar
Re: 700r4 is in.
So based on what I read here a 30% overdrive with 3.08s is too much overdrive, but 3.73s would be better. So the doing the math it sounds like the a good "amount of overdrive" is about 13% over stock, does that sound right?
My reasoning; 3.08s are turning the engine 17% slower than 3.73s at the same road speed, then add in the 30% overdrive with the 3.73s and you have a total change of 13% [30-17].
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 11-28-2005, 08:42 PM   #27
mocwon
Keep On Truckin'
mocwon's Avatar
Re: 700r4 is in.
Originally Posted by Longhorn Man
I'll bet a punch in the gut that your MPG will not go up by much... if at all. Lower RPMs do NOT always mean better MPG. your freeway RPM there is simply too low and it is under the curve.
If lower is better was true, then all the new stuff would have 2.50 or so gears.... or a straight one to one and overdrive.
It simply wouldn't work.
Try the 3.42, that is probably your absolut best bet.
Onless you have a motor with gorlla low end torque like a 455, any caddy big block, or a diesel.
I've confirmed what Longhorn Man has indicated. I was kinda' from Missouri when he replied I shouldn't sell my 3.42 gears sooooooo, I went and talked to the tranny guy that built mine and hundreds like it along with a slew of racing, towing and other trannies as well. He said that 3.42's should be the minimum for stock height tires but that 3,73's would be likely be better, depending on the type of driving I do. As others have said, the tranny will hunt for gears and not go into overdrive unless way over the speed limit. I'm going to run the 3.07's (see Longhorn Man, even an old coot like me can change) awhile to prove it to myself (substitute hard-headed here) and will most certainly move to the 3.42's.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 11-28-2005, 11:55 PM   #28
Sonny
Active Member
Re: 700r4 is in.
My electrical system working fine. I have an underdrive pulley kit (March) and a chrome aftermarket one-wire alternator (rebuilt by a reputable alternator shop in town about 6 months ago). Everything was fine before the March pulley conversion. I'm not worried; I just have to make sure I give it a little humph when I get going when I bring the beast to life!
Sonny is offline   Reply With Quote
Old 11-29-2005, 08:09 AM   #29
Buckman
Re: 700r4 is in.
Mocwom, what is your rpm to mph ratio? Like 60 and 70 mph.
Buckman is offline   Reply With Quote
Old 11-30-2005, 08:23 PM   #30
MrC1
Dork For Days
MrC1's Avatar
Re: 700r4 is in.
Hey guys, nobody mentioned anything about lock-up vs. non-lock-up 700R4s here. I'm running a non-locker with 3.54s and it feels about right. I'd prefer to add the lockup and some more gear, but...
Think I'll post a question about adding lockup.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 11-30-2005, 10:14 PM   #31
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 700r4 is in.
That's becouse we are talking manual shift
Thread Tools
Display Modes
