#26 |
Re: What are the difference between leafs?
sorry to hear that, twas worth a try though. ttt 4 u
#27 |
Aluminum slot wheels rule...
Anyone else wanna chime in and tell me the differences between 67-68 and 69-72 leaf springs, and whether I can use 69-72 springs on a 68?
#28 |
You could change out the hangers.
#29 |
Arent the front hangers riveted on? I looked in LMC catalog, and front leaf springs are the same 67-72. they only list them for one application, anyway. are the rear one bolted on?
#30 |
Last TTT
#31 |
Can anyone else tell me whether the leaves are different for 67-68, and 69-72. I need a stone carved answer, this thread didn't provide much useful info, if you couldn't already tell.
#32 |
Not a bad nut after all..
Are 4x2 rear leaf springs interchangable with 4x4 rear leaf springs (other than ride height)?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
#33 |
![]() Join Date: Aug 2005
'67 and '68 GMC 4X2 leaf springs are unique. They are 2 1/4" wide. The '67 and '68 4X4 (both GMC and Chevy) rear leaf springs are different. They are taper leaf, use different hangers and bushings, and the axle U-bolts have the nuts on top, so the brackets welded to the axle are different, too. '69 and up leaf springs are wider on both 4X2 and 4X4 (I think they are 2 3/4"), though all the axle U-bolts have the nuts on the bottom. So, leaf springs between '67-'68 and '69-'72 will not interchange. '67-'68 4X2 and 4X4 leaf springs will not interchange. I don't know if '69-'72 4X2 and 4X4 leaf springs will interchange, but they use the same bushings and shackles, so they might.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
#34 |
What about the front leafs?
#35 |
You got me there. I have only messed with rear leaft springs.
Thread Tools | |
Display Modes | |
