Old 01-15-2007, 01:02 AM   #26
Critter
Future TOTM Winner
Critter's Avatar
Re: K5 Body Mounts
I got all of the bolts and old body mounts removed. Unfortunately the PO had welded all of the bolts to the floorboard. Thanks to a lot of help from JTRUX and his grinder, we got everything removed. Anyway, to make a long story short, I don’t believe any or my bolts are original. I would really like for someone to help me out with the diameter and lengths of these bolts. The ones that were there are too big to go back into the new washers that came with my Energy Suspension kit. Also, the diagrams that I have seen show that all of the original bolts should be carriage bolts, except the one right under your feet in the floorboard. Is grade 8 entirely necessary? Has anybody had trouble with using a grade 5 under normal conditions? I have a feeling my floorboards would crack before I broke a bolt. I appreciate any more info.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-15-2007, 03:56 PM   #27
Critter
Future TOTM Winner
Critter's Avatar
Re: K5 Body Mounts
OK, I feel dumb. After doing a little research, it looks like the factory welded the bolts to the floor pan. At any rate, I still need some new ones. What doesn’t make sense is that the Energy suspension kit won’t allow me to use the same bolts. If they are indeed the original ones, they are too big for my new kit! Any ideas???
Old 01-15-2007, 08:14 PM   #28
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Re: K5 Body Mounts
Wish I could help, Critter, I am using the LMC rubber set and I compared a couple of the bolts and they seem the same. Havent opened all yet as each position is individually packaged. The foot area bolts in mine look like grade 5(3 lines on the head) so I wonder if your stuff was changed before and welded back in like factory. That's 1/2" bolts so grade 5 should sure be enuff, especially when you consider that they get torqued 40-55# according to the assembly manual.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 01-29-2007, 09:39 PM   #29
1972 Banana
1972 Banana's Avatar
Re: K5 Body Mounts
Critter,
Sorry I never got you the bolt info! I ended up ordering mine from LMC it cost me about $40.00,the floor board bolts that were in mine were to big for my washers that came with the kit. the local Ace Harware store had some fender washers that worked just fine.If you still need the info I will try to find the piece of paper at work with the dimensions. My local bolt supplier could only sell them to me 25 at a time!
1972 Banana is offline   Reply With Quote
Old 01-29-2007, 11:45 PM   #30
Critter
Future TOTM Winner
Critter's Avatar
Re: K5 Body Mounts
That was my problem. I ended up drilling out the washers for the radiator support and the main floorpan. The bolt in the floorpan was between a 1/2 and a 5/8 so...maybe it was a 9/16. Either way, I put a 1/2 in it for now. Maybe I will change it if I can find the right bolt someday.
Old 02-09-2007, 05:26 PM   #31
5150
C10 Club Tennessee
5150's Avatar
Re: K5 Body Mounts
1972 Banana-Anymore info on the length of the bolts?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 02-09-2007, 06:32 PM   #32
1972 Banana
Re: K5 Body Mounts
The bolts I had to replace were as follows
3/8 by 4 1/2 inch two of them
3/8 by 10 inch two of them
3/8 by 5 1/2 inch four of them
the other bolts I was able to salvage but the floor pan bolts were to big for the washers in the kit so I was able to get a fender washer from the hardware stor and it worked ok.
Old 02-09-2007, 11:49 PM   #33
5150
C10 Club Tennessee
5150's Avatar
Re: K5 Body Mounts
How many bolts in all? 14?
Bryan
www.gmtruckshow.com
Old 02-14-2007, 10:25 AM   #34
Critter
Future TOTM Winner
Critter's Avatar
Re: K5 Body Mounts
By my count, I remember 12:
Under radiator support x 2 (7/16 I think)
Main cab support in floor pan x 2 (slightly larger than 1/2" maybe 9/16ths?)
"Bed area" x 8 (see 1972Banana's list above)
Sorry for not remembering the lengths. I had to make a couple of trips to the hardware store to get things right. Obviously, too short is a problem, but you can easily go too long as there are often brackets and things directly below the mount areas. I suggest pulling one out from each side and taking them to be matched up. Also, I called Summit and asked about the bolts, they confirmed with Energy Suspension that ALL of the bolts are specialty bolts and no hardware store will have exact matches for them. In my opinion, try to reuse the large bolt in the floor pan area, it seams the have very odd dimensions and tapers. Otherwise, the rest of them cross over with regular hardware just fine. Hope this helps.
Old 02-16-2007, 02:16 PM   #35
1972 Banana
Re: K5 Body Mounts
12 bolts total,8 are 3/8th. The hardware store bolts I found were grade three's and are not strong enough,I ended up getting them from LMC.
Thread Tools
Display Modes
