05-06-2007, 11:01 PM | #26 |
67-72 Addict!
Re: 2/4 drop?
If they pop (moving in the spring pocket) it's probably due to being cut too short. I wouldn't go more than a 3" spring in front if you decide to cut. Another reason to not go too short, is they might fall out when jacking the truck up to put it on jack stands.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-07-2007, 01:04 AM | #27 |
Re: 2/4 drop?
In the late 80's (geez I'm getting old) we used 68-72 El Camino rear coil springs... The Hef-T-Coil style from Moog... they were for extra hauling in El Camino's... also I don't remember how much lowering that got you, but I then added a 2" block between the trailing arm and rear end... it was LOW for back then... and cheap... I was about 21 or 22 then... it must have been cheap...
Remember, that was before ECE or anyone from what I can remember, Oh, Maybe Traders Trucks....
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 05-07-2007 at 01:05 AM. |
05-07-2007, 03:07 AM | #28 |
Re: 2/4 drop?
I don't want my comment taken the wrong way so please try to understand the point that I'm attempting to make here.
If I needed a work truck (a practical truck) I would leave my truck stock or buy a second truck for the above various needs. Where I live 3 grand buys a really nice dependable and pretty good looking truck in the 80's. I'm not a fan of trying to make 2 trucks out of one. Hot Rod's, Kustoms and Street Rods are (IMO) to be enjoyed for what they are .... truck's that have earned their retirement. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
06-15-2007, 12:25 AM | #29 |
Re: 2/4 drop?
Hey thanks for the props... No you don't need a C- Notch or anything. You just need some knock-er Loose for the rear retainer bolts and a BFH for the front ball joints... assuming that you're replacing them. Deffinitly get the front end aligned after you put the spindles on... I tore through a set of tire in a couple of weeks ooops!
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
06-15-2007, 12:40 AM | #30 |
drive it till it dies
Re: 2/4 drop?
the cheapest way is to heat the coils and hold a yard stick up to the fender until you reach the desired height. you can do this for the fron and back unless you have leafs in the back, if so take out all leafs except the long leaf and helper leaf. you should get a good 3-5 inches out of that. the heating does the same thing as cutting but is much easier because you do it while they are still mounted and you can get an even ride height. plus all this is totally free and it works. i have done this on older trucks and newer models. as long as its a gmc or chevy you are good. fords not so good.
Thread Tools | |
Display Modes | |
