Old 05-11-2007, 03:18 PM   #26
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: Gas Tank Removal Questions
It can be done without removing the bed, but be prepaerd to be huddled under your truck in awkward positions for 30 minutes at a time while you try to get the lines off and back on again. Then expect to be sore from it for hours after, and also taking breaks every 20 minutes or so because the gas fumes coming off the tank while you're crouched under there will nearly make you sick after a while.
Ive dropped my tank twice, and it was 10 times easier when we pulled the bed first.
xtreme80 is offline   Reply With Quote
Old 05-12-2007, 12:41 AM   #27
tyjoja
bed is fairly easy to pull, I pulled mine with plenty of help from this forum. 8 bolts to the frame. Unplug the taillights and license plate lights, check for a ground stap to frame(mine didn't have one) and get a strong person on each corner, and lift it off. Lol
tyjoja is offline   Reply With Quote
Old 05-13-2007, 12:56 PM   #28
HOGDADDY
HOGDADDY's Avatar
Speaking from experience: Do not try this without FIRST taking the bed off its simple but you will need at least 4 strong guys.
HOGDADDY is offline   Reply With Quote
Old 01-01-2008, 09:23 PM   #29
sighlurr
______________
sighlurr's Avatar
I just pulled mine last weekend and didn't disconnect a rearend vent hose that was attached to the bottom of the bed.
Anyone else have this?
sighlurr is offline   Reply With Quote
Old 01-01-2008, 09:31 PM   #30
sighlurr
______________
sighlurr's Avatar
Re: Gas tank removal questions
This site saves me again.
Old 01-02-2008, 07:07 AM   #31
xtreme80
xtreme80's Avatar
Yes.
Old 01-23-2008, 04:32 AM   #32
72GMCburban
72GMCburban's Avatar
here is a dumb question, but where does the tank wire harness go to? I know it hooks up on the sending unit, but where does the other end attach? Is it a ground? Power? Anybody got a pic or diagram? I pulled some wires after a little wire fire and now the engine is not getting fuel!
72GMCburban is offline   Reply With Quote
Old 05-12-2015, 10:29 PM   #33
albertgen
What is the size of those bolts that hold the gas tank? I am going to replace my gas tank and I thought I would replace the bolts with stainless steel bolts. Thanks, Al
albertgen is offline   Reply With Quote
Old 05-13-2015, 09:40 AM   #34
KrazyRay
KrazyRay's Avatar
Just to clarify this 10 year old thread, the 87 1 ton tank bolts are tough to get to unlike all of the other trucks. There is a frame cross member in the way and those tank straps do NOT come with the captive nut. I've pulled hundreds of tanks and these ones are brutal to remove even with the bed off. By the way, the bolt size is 3/8" with a 9/16" hex head.
KrazyRay is offline   Reply With Quote
Old 05-13-2015, 09:51 AM   #35
hatzie
Moderator
hatzie's Avatar
Ground goes from the sender ring to the frame except the TBI trucks that have a harness going through the top of the sender into the tank with a ring terminal on the end of the ground wire.
The sender wire itself goes to a pigtail on the RH frame rail. On single and dual tank systems the pigtail wire on the RH frame rail goes to the bulkhead plug.
On 73-80 dual tanks both sender wires go to the dash switch and one wire goes back to the RH frame rail pigtail wire.
On 81-91 dual tanks the sender wires go to the valve and one wire goes to the RH frame rail pigtail wire.
TBI trucks have a 2 position Weatherpak disconnect and a ring terminal ground on the frame.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Thread Tools
Display Modes
