06-25-2007, 02:18 PM | #26 |
Happy to be here
Re: 18,19,20's wheel size.
Yeah, and wasn't that built as the guys tow rig...
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-25-2007 at 02:18 PM. |
06-25-2007, 03:33 PM | #27 |
Yep... For their Cobra racer ( I think it was one of those Super-perf Cobra-Kit cars).
06-25-2007, 04:47 PM | #28 |
Is it just me or do most all of these trucks have torque thrust style wheels? I'm not saying they dont look good but wow I never really payed attention to how many people have them on their trucks. I dont know but its my 2 cents and yea the stagared look looks awsome.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s |
06-25-2007, 05:32 PM | #29 |
When I started looking around for wheels I noticed a lot of these trucks with Torque Trust Wheels. I love the look but elected to try something different. I am also going with a stagger look
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
06-25-2007, 07:32 PM | #30 | |
06-26-2007, 04:39 PM | #31 |
Many newer wheels are being made in China. Talking to a wheel and tire guy he says, "We have a hard time with some of these wheels imported from China and other foreign countries, because they just do not balance out well. We end up using a lot of wheel weights on them." It is better to order true wheels manufactured from companies like Centerline, Boyd, or Billet Specialties which have higher quality standards.
06-28-2007, 02:06 PM | #32 |
If you run 5.0 Backspacing on a 18x8" rim in the front, what spacer (adaptor) would you need in the rear on a 20x8.5 with 5.4 backspacing?
06-28-2007, 02:51 PM | #33 |
im not 100% sure.. but i would think a 1" would be ideal
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
06-28-2007, 02:56 PM | #34 |
1 ~ 1.5".
An 8" wheel w/4"BS works great on 67-72's. Add an extra .5 to that wheel width to the outside edge of the rim to try & keep the BS around 4". 5.4" - 1.5" = 3.9" which is pretty darn close to the magic number. IMO though, wheels w/that much BS & a spacer to center them properly aren't going to look as good as the correct size/BS wheel w/no adapter.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-28-2007 at 02:59 PM. |
06-28-2007, 03:15 PM | #35 |
5.0" backspacing in the front for the 18x8 is all that is offered. on the 20x8.5, 5.4 is all that is offered.
06-28-2007, 03:38 PM | #36 |
They are sending me the wheels to test fit and if they don't look right. I can send them back at thier charge but the catch is that I order a set of wheels with custom backspacing which cost twice the original cost. I already know that I will have to use the adaptor/spacer on the rear. Does anybody have pics of a 5.0" backspacing on the front? 18x8" or 20x8"?
06-28-2007, 04:13 PM | #37 |
check "gringoloco" blazer thread, his wheels are just about perfect setup
06-28-2007, 04:22 PM | #38 |
My truck is apart again now but I have 20x10's w/5 1/2"bs and 18x8's w/4 1/2"bs up front. The rear fill up the wheel opening very well as do the fronts. I have 295/40/20's and 255/55/18's.........the truck has a 4/6 drop.......these tires are a little tall but I wanted to raise the ground clearance a little because of my rear mounted fuel tank and 3" exhaust........
06-28-2007, 04:27 PM | #39 |
He has a different setup, but thanks
06-28-2007, 04:35 PM | #40 |
check 68fleets hes running 20x8.5" and is the one that told me about the spacers, search his threads
06-28-2007, 05:11 PM | #41 |
Nothing came up only this thread
06-28-2007, 05:21 PM | #42 |
The 5" BS for the front is good. It's the rear BS I was explaining & the effects on the overall 'look' of the wheel/tire combo on the truck.
06-28-2007, 05:28 PM | #43 | |
I think I will be running som Adaptors but I am just not to sure what size maybe 1.5"?? the front is going to be 5.0" bs w/ an 8" rim ther rear is going to be an 8.5" rim with a 5.4" bs either a a 1" or 1.5" Adaptor should work?? I dond want the tires to set in to far.
06-28-2007, 05:46 PM | #44 |
sorry.... 67fleet heres a link to some pics/info
http://67-72chevytrucks.com/vboard/s...d.php?t=213522
06-28-2007, 05:49 PM | #45 |
c10ss69, those look like those FOOSE wheels I've been wanting to get for mine. If you don't mind me asking, how much did those cost you, and what's the color you've got on those valve covers?
06-28-2007, 07:32 PM | #46 | |
I would go w/4" BS on the rear. So.... if you use the 5.4"BS wheels, you'll want the 1.5" adapter. What size tires again?
06-28-2007, 07:37 PM | #47 |
A guy with a truck
Remember, he has the 'wide' rear axle. 4.5 would probably be optimal. Best thing to do is get in there and measure. I got the smoothies w/ 5.4 BS and a 1 1/4" adapter. Your results may vary...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-28-2007, 08:38 PM | #48 |
This is what I recommend 100%. I would never buy a wheel based on someone elses measurements unless they took those measurements off of my truck.
06-28-2007, 09:02 PM | #49 |
245-45-R18 in the front and 275-40-R20 in the rear. When I pulled some measurments on my truck I came up with a 1" to 1.5" adaptorin the rear. It was hard to be exact without wheels to test fit
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 06-28-2007 at 09:05 PM. |
06-28-2007, 10:06 PM | #50 | |
See how a known wheel fits & get BS measurements. Then add or subtract the difference of the 'new' wheels BS & see how far in or out you need to go.
Thread Tools | |
Display Modes | |
