On the fast track to nowhere..
Re: Lower A-arm ???
i USED 1/4" pipe and 1/4" plate for the bottom
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
Texas Big Wig
http://67-72chevytrucks.com/vboard/newreply.php?do=newreply&noquotRe: Lower A-arm ???
ok guys, here it is
I'm back from see'n my brother & bag'n the front of my truck I took a lot of pics, so I'm not gonna post em all... Here is a link Ima skip the disassembly & start with the good stuff Cut'n the bump stop off ![]() ![]() Bolt the upper plate to the bag & mock it up ![]() ![]() Made the lower cup ![]() ![]() ![]() ![]() ![]() |
Texas Big Wig
Re: Lower A-arm ???
Mocked up the lower cup & A-arm, so we could trace where to cut
![]() ![]() ![]() Cut'n out ![]() ![]() We leveled the cup to the bottom edge of the A-arm ![]() ![]() ![]() |
Texas Big Wig
Re: Lower A-arm ???
Drilled a hole it the cross member & put a grommet in for the hose to run through
![]() ![]() Bag installed for good ![]() ![]() ![]() ![]() My temp for airing them up ![]() ![]() |
senior member
Re: Lower A-arm ???
how are you guys determining where to cut for the pipe?
69 GMC bagged |
Re: Lower A-arm ???
I just centered the pipe over the spring pocket and drew around it. Then I made the top plate and bolted it on, bolted the bag in the lower arm an bolted it on. Then I lifted the lower arm until the bag touched the upper plate and drew around the bag to mark for the mounting holes and air line hole in the plate. This way it is aligned perfectly. Hope that makes sense, it's hard typing something this long on my pda
senior member
Re: Lower A-arm ???
some what makes sense when ur talking upper plate im assuming the one bolted to the crossmember? I already have the bag in the front so basically what ur saying is now draw a circle around the bag? and that should give me a rough idea?
69 GMC bagged Last edited by pissonNOS; 08-08-2007 at 11:22 PM. |
#9 | |
Texas Big Wig
Re: Lower A-arm ???
But I haven't got that far yet, I may wind up doing it like Mike (like mike... ha ha , I made a funny) |
Re: Lower A-arm ???
[QUOTE=Spray-Bomb;2301388]I like mikes idea as well, but I plan I taking my pipe & centering it over the original pocket in the A-arm and trace around it so I know where to cut
QUOTE] I just caught what he's saying. I thought he was just installing but he's already all hooked up and just wants to mod the control arms. Duh. Yeah, I'm going with he original plan. Center the pipe over the pocket and draw around it ![]()
#12 | |
Re: Lower A-arm ???
No problem Matt.
#13 |
Re: Lower A-arm ???
Looks good dude! Now it's time for the back!!
#15 |
![]() Join Date: Aug 2005
Re: Lower A-arm ???
Wow, nice work on the arms. Do you have drop spindles? ...and that line routing through the crossmember looks familiar
#16 |
Re: Lower A-arm ???
nice work !!!!
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
#18 |
Re: Lower A-arm ???
lookin' good!
#19 |
Texas Big Wig
Re: Lower A-arm ???
Do any of you mods wanna make a FAQ out of this thread from post 34 though 40 ???
I find myself digging it back up & posting links to it fairly often Just a thought, Matt |
#20 |
Re: Lower A-arm ???
I brought it to their attention for ya.
#22 |
Texas Big Wig
Re: Lower A-arm ???
Frizzle, if you wouldnt mind bringing it up to them again I would appreciate it, as I just had to dig it up again for reference in a thread
#23 |
Re: Lower A-arm ???
Does this mod gain you any extra drop opposed to cut SD/ART cups or just for better ride height?
#24 |
VA72C10
![]() Join Date: Mar 2008
Re: Lower A-arm ???
Also, how much lower would this be than what you get w/ 2.5" drop spindles (1/2" or .3"?)
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#25 |
Texas Big Wig
Re: Lower A-arm ???
It lets you ride a couple inches lower than if you have the spacer cups & when you lay out your LCAs will touch the upper bag plate instead of your bags bottoming out
All it really does is let you ride a lil lower with your bags at a good height... Basically your bags are 6-7" tall when your control arms are basically level And it will let it lay out a lil more If you click the link to Killers build thread in my sig, you can see what it will do Last edited by Spray-Bomb; 12-10-2008 at 02:18 AM. |
Thread Tools | |
Display Modes | |
