Old 08-13-2007, 04:28 PM   #26
67ChevyRedneck
67ChevyRedneck's Avatar
Re: 4 core radiator and thermostat...
Funny you should mention them, a guy at work mentioned them too...
I might mock up my cooler and drive over there.
I think I've got most everything figured out
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-13-2007, 11:47 PM   #27
roughedup72
roughedup72's Avatar
I just added one to my truck today. Not to bad of a job to do. I got it from advanced auto. I also have a problem with my truck running the temp up while I'm running the A/C. I have a 4 core radiator as well and cant seem to keep it cool when I'm in stop and go traffic. Once I get it out on the intersate as long as the traffic is flowing it does seem to run at about 185. I am thinking of going with a 160 degree thermo in mine to see if it helps me some.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 08-14-2007, 12:06 AM   #28
Texasdeere
Texasdeere's Avatar
What fan and shroud set up do you have on your truck? Sounds like an airflow problem at slow speeds.
Texasdeere is offline   Reply With Quote
Old 08-14-2007, 12:11 AM   #29
roughedup72
stock fan,no clutch, stock shroud. I noticed this situation after adding the heater control valve back into the system. I think I have it connected wrong.not sure if it matters though.
Old 08-14-2007, 11:07 AM   #30
67ChevyRedneck
I put the cooler on yesterday, unfortunately, I won't be able to get to the lines for a week or two, I'm leaving for NY in a couple days. You can't see it at all under the truck. It was a pain to get it level because of the low hump in the middle of the crossmember. I put it as far to the driverside as I could to leave room for the lines. They'll run between the crossmember and the radiator...everything is right there! This is the one that has the two inlet/outlet on the same side.
Jesse James
Project "On a Dime"
Old 08-14-2007, 11:12 AM   #31
67ChevyRedneck
Before you added it, some heat was probably being let off by running through the heater core, but now that you have a valve that closes it, nothing can run thought it.
Jesse James
Project "On a Dime"
Old 08-14-2007, 12:54 PM   #32
OLDIRON69
Heater core= mini radiator
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Thread Tools
Display Modes
