Old 10-30-2007, 12:02 PM   #26
collin86
Re: 500hp
i have future plans of a turbo 572ci
collin86 is offline   Reply With Quote
Old 10-31-2007, 01:12 PM   #27
streetstar
streetstar's Avatar
Re: 500hp
And that ------ is Pro/Mod territory, power wise. Time to order a Lenco
streetstar is offline   Reply With Quote
Old 11-03-2007, 11:10 AM   #28
collin86
Re: 500hp
yeah, i have to start saving for that one
Old 11-28-2007, 12:49 AM   #29
collin86
Re: 500hp
i was just reading an article in car craft about a 383 build that made 540hp and something like 517 ftlbs on pump gas and no NOS all for $4800. its worth reading.
Old 11-28-2007, 10:57 AM   #30
Roper
Re: 500hp
On Power Block TV they had Gale Banks on their and they built a 1500 HP SBC.
I actually looked on the Banks web site and couldnt find any info on the build or any info for SBC but anyway they did it on Power Block (TV CAR shows on Spike TV}
Roper is offline   Reply With Quote
Old 11-28-2007, 11:03 AM   #31
collin86
Re: 500hp
thats a lot of power out of a sbc
Old 11-28-2007, 02:05 PM   #32
Pyrotechnic
Pyrotechnic's Avatar
Re: 500hp
This must be one hell of a 73-87 were talking about here.
Pyrotechnic is offline   Reply With Quote
Old 11-28-2007, 02:29 PM   #33
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 500hp
i will try and get some pics soon, its all in parts now, but i will see what i can do.
how does $4800 sound for the whole motor. not bad i think. i was hoping to hit the 11's on this set up, but who knows.
yeah i will be running slicks at the track prolly a 29x16x15 or something like that. im hoping i will be able to get tire spin at close to 50mph, im gonna have to use some crappy tires for awhile to get the burnouts out of my system. i dont want to burn out $400's per tire
If you can put 500 HP at the crank for $4800.00, then you are pretty good. Hopefully you are doing the assembly and the price that you quote are the parts prices. The reason I state this, that type of power needs a good quality parts list, for longevity. I agree with others that the motor will tear everything else up trying to do what you want it to. A good tranny, driveline and axle setup is paramount to your making the power and getting it to the road.
I don't have 500 HP, but my 84 SWB with a 385 stroker motor is pushing about 400 at the crank and it can be hard on the rear end parts, if I want it to be.
I had to pay a little more than the $4800.00 [rice for the motor work and parts.
piecesparts is offline   Reply With Quote
Old 11-28-2007, 02:40 PM   #34
space
Re: 500hp
It took me less than 20 miles to fry my stock 350 tranny, so I agree on the being hard on the drive train.
space is offline   Reply With Quote
Old 11-28-2007, 10:55 PM   #35
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: 500hp
my 383 with a turbo 350 both bulit. it is hard on my rear. it is a 373 lock right locker. 295/50/15 and it will hook but not good and you can tell it is takeing a @am beating. i dont know the hp on it i bought it that way
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 11-29-2007, 12:49 PM   #36
collin86
Re: 500hp
well i am in the process of assembling my rearend right now. its a 9" rear narrowed, 40 spline chromoly hardened strange axles. 40 spline spool (it was my only option) aftermarket strange carrier case, forged yoke, 4:10 yukon gears. if i brake 40 spline axles there is something seriously wrong. im also working on my 4 link and coilover rear
as for the motor and tranny, forged internals on the motor
the price i gave is for parts and machine work, i assemble myself, but it doesnt include headders or distributer, cause i had those lying around already
tranny= viper t56
Old 11-30-2007, 10:44 AM   #37
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
Re: 500hp
How does it feel? Well how heavy is your truck? If you are moving 6000lbs, then it will feel like you are driving a mid 13 second vehicle, but one that uses torque to move and it wont be violent feeling at all. If your truck is 1800lbs, tube frame with all body parts being fiberglass, then when you stomp the skinny pedal on the right it will feel like you were rear ended by a semi doing 65 mph.
Some of us are very impressed by a big HP number, but the HP alone can be misleading. HP is derived from a mathematical equation. Torque x rpm / 5252 = hp. So the higher the rpm the higher the hp provided it still makes torque above 5252 rpm. You can get 400 hp from a 289sbf or 283sbc relatively easily, just spin it to 8000-9000 rpm and make about 250ftlbs of torque there. It will make 400 hp but feel like a pooch under 6500 rpm.
I guess my point about that is it depends on the vehicle and where the engine makes the power that matters. I tend to prefer the engines that make 500ftlbs just off idle and around 600-700ftlbs at 6000 rpm. They need a big arm or a blower to do that, but that makes for the most fun cruising around.
For reference the 455 Pontiac that was in my street/strip Firebird made 540hp@ 5800 and 564ftlbs@ 4000, had to over gear it to keep it in the 12s and avoid the expense of the cage and other safety items needed for 11s at the time. But at 3700lbs it ran 12.0 very consistently with 4.11 gears, with a best of 11.7@115. When I put the 3.42 gears behind that torque monster it picked up a bit and started running 11.50 through the mufflers until it broke the Th400. Being a relatively heavy car it wasnt super fast, but dropping the same engine in my 5000lb 76 would slow it even further. That isnt even considering the aerodynamic requirements of pushing double the frontal area over 100mph.
If you have a ton of torque and it happens to make a bunch of HP, then it will still be a fun ride. If you have a heavy truck with an engine that lacks bottom end torque but has 500 hp over 6000 rpm, it will feel sluggish until you get it wound up into the power band.
Just FYI nd a bit of bragging.. The 462 ci Pontiac that made that power cost me a grand total of $2700 to build, it ran brackets twice a month and street raced quite often for 7 years. The only thing that killed it was when someone push lead shot in the valve cover, and a piece made it through the pump screen, pump, and into a main bearing. I guess the sbc crowd doesnt like to lose to a grocery getter that never sees over 6000 rpm.
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 11-30-2007, 11:21 PM   #38
collin86
Re: 500hp
sounds like a mean motor to me. while i belive my truck weighs around 4000 and i should be making about 525hp and about the same amount of torque all about 4-6k rpm. with 4:10 gears and a t56 it should be pretty fun to drive on the street
Thread Tools
Display Modes
