Old 01-02-2009, 03:13 PM   #26
nac593
Re: Gravity Bleeding Brakes
I got the fluid going. I changed the brake hose and now it flows. That's what ECE told me. Maybe I should call them.
nac593 is offline   Reply With Quote
Old 01-02-2009, 07:00 PM   #27
71tahoe
71tahoe's Avatar
edited my stupid response.
Last edited by 71tahoe; 09-15-2009 at 04:45 PM. Reason: I must have been having a real bad day
71tahoe is offline   Reply With Quote
Old 07-23-2011, 04:50 PM   #28
-sean-
Bringing this back up, again.
Question: I can not get any fluid to flow through the rear brakes. I have new rear brakes including the wheel cylinders, MC and PV. I have the button on the PV pressed in and both rear valves are open.
Any suggestions?
Update: Checked the PV and it had the rear brakes blocked (rod inside pushed to the rear) so I reset it.
Also, when the button on the PV is pressed in it will leak break fluid from around the button. Does that button need to be pressed in to gravity feed?
-sean- is offline   Reply With Quote
Old 07-24-2011, 07:05 AM   #29
dznucks
dznucks's Avatar
How old is the PV? It may be worth replacing. Mine was stuck like yours and i had no luck resetting it.
Try cutting 2x4 long enough to brace between your bench seat and the brake pedal. the idea is to depress the brake pedal about an inch and hold it there. try gravity bleeding again. also make sure your rear rubber line hasnt collapsed. after i replaced my PV, i ran into a collapsed line that looked perfectly fine.
dznucks is offline   Reply With Quote
Old 07-24-2011, 06:05 PM   #30
-sean-
Thanks for the reply...
The PV is new and the rear line "seems" fine but I will pull it out and check it.
I also borrowed a vacuum bleeder and thought I might give that a try too.
Thread Tools
Display Modes
