Old 04-26-2011, 11:10 PM   #26
jocko
jocko's Avatar
Re: Wheel Openings Are Different!
Oh I agree with you on that point Lakeroadster - but not many folks are putting 33s on their truck - I felt lucky to find 3o" tall tires in the 75R15's I put on. But yes, with drag slicks or big mickey T's, they would certainly look just about right. Problem is - many of the shortened long beds have much smaller than 33" tires. But they all still look good I believe. I think it's one of those things you'd never notice if someone didn't tell you because either way looks right.
Old 04-26-2011, 11:23 PM   #27
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Hope I have the right wheel opening sections coming.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 04-27-2011, 02:44 AM   #28
Frizzle Fry
Frizzle Fry's Avatar
FYI, I measured a LWB arch vs. a SWB arch and found right about 1" difference. Anyone else?
Frizzle Fry is offline   Reply With Quote
Old 04-27-2011, 10:12 AM   #29
lakeroadster
These little differences are neat!
As a visual reference the picture below shows a shortbed and a longbed. The measuring scale is of course not to scale but it does clearly show their is a difference in wheel well opening lengths.
(Vertical white lines are to show the pictures have been scaled so the cabs are the same length.)
lakeroadster is offline   Reply With Quote
Old 01-29-2012, 03:13 PM   #30
padresag
Originally Posted by lakeroadster View Post
Because they knew that 50 years later Hot Rodders would be modifying these trucks and putting huge diameter tires on them?
In reality, IMO, those big wheel well openings look great with 33" and larger dia. tires sizes. No different than making the rear wheel wells bigger on a car being set-up for drag slicks. Novas, Camaros, Vegas... pretty common place then and now.
Maybe the answer is they did it for the NAPCO trucks???
Something for everybody here I guess. It's all good.
John
but the Napco trucks in this vintage was only 133 " w/b and up
ron
padresag is offline   Reply With Quote
Old 01-29-2012, 04:17 PM   #31
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I think it was for proportional reasons.
Nothing to back up my theory.
66 C20 Service Truck:
Old 01-31-2012, 12:06 AM   #32
mMad Dawg
I'm working on a 66 Chev panel. I'm using pickup wheel opening repair panels. When I held them up to my truck they were about 2'' too long . I ended up taking out 2'' out of the center, they seem to fit good now . Hope this helps.
mMad Dawg is offline   Reply With Quote
Old 01-31-2012, 12:31 AM   #33
dugvera@gmail.com
dugvera@gmail.com's Avatar
am i confused or is this going against panel=long burb=short theory?
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
Old 07-02-2012, 08:42 PM   #34
piratexpress1369a
piratexpress1369a's Avatar
just to be clear on this ,on my 63 panel do i need a long box quarters or a short box??
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 07-03-2012, 12:16 AM   #35
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I am pretty sure panel and sub = short, and 1 ton long panel = long.
Old 07-03-2012, 08:00 PM   #36
mMad Dawg
Red face Re: Wheel Openings Are Different!
I guess I should have made myself clearer. The repair panel I used was for a longbox pickup, I couldn't find one for a shortbox. Actually I didn't know until I held it up to my panel that there was a difference. Thats why I took some out of the middle. The panels and subs are different from the wheelwell back, I used parts of a repair panel for 73-87 pickup. In front of that I was able to use part of a rocker panel repair piece. Hope that helps you.. Gord
Old 07-04-2012, 09:05 AM   #37
piratexpress1369a
does any body know if they still make a full fleet side panel or is it just sold in a 3 piece sections
63
Old 07-04-2012, 11:35 AM   #38
factorystock
factorystock's Avatar
What's bugging me, and the one question I haven't seen answered is "why" did GM make 2 different size wheel openings? I can't imagine why a longbed and panel would need a longer opening that a shortie and suburban...
There is a simple explanation for this. 3/4 ton pickups and 1 ton panels could be ordered with optional 17" and 19.5" wheels. These are large diameter wheels and tires that weren't availabe on 1/2 tons. Extra clearance for tire changes and or installing tire chains.
factorystock is offline   Reply With Quote
Old 07-04-2012, 11:46 AM   #39
padresag
so subsequently did this make a difference in the inner wheel tubs and floorboards?
ron
Old 07-04-2012, 02:21 PM   #40
factorystock
Everything else is the same, if you ordered a 8' fleetside, 1/2 or 3/4 ton, you will get the same bed. Would not have been worth the extra expense for GM to tool a different bed panel on 8' 1/2 tons fleetsides.
Old 02-20-2015, 11:06 PM   #41
aspiringthomas
aspiringthomas's Avatar
Originally Posted by CHIZZLER View Post
Long bed cut down.i like the bigger wheel opening.
Never knew.
aspiringthomas is offline   Reply With Quote
Old 02-22-2015, 07:31 PM   #42
frankslagoon
Originally Posted by PGSigns View Post
That 3" differance must be why the short beds look like the wheel is sitting a little forward in the wheel well and the long beds don't look that way.
Jimmy
Somebody mentioned in another post today that usen drop springs pivots the axle forward on the trailing arms. So that's a lot of what we see I bet.
frankslagoon is offline   Reply With Quote
Old 12-09-2015, 09:59 PM   #43
LostMy65
LostMy65's Avatar
I wonder if now that they have shortbed besides available, if they might also make available patch panels with the shorter wheel opening.
Old 09-22-2017, 08:30 AM   #44
randoosrods
Thanks that will help!
randoosrods is offline   Reply With Quote
Thread Tools
Display Modes
