Old 05-09-2008, 06:18 AM   #26
87 dually burb
my short bus
87 dually burb's Avatar
Re: dually burb project in Va
I have it for sale on pirate 4x4
I sold off my other projects and parts
buying a 20' trailer late may need the $
lookin at a few 68-72 nova projects
got the street/track bug again
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 05-09-2008, 06:33 AM   #27
72 CustomCamper
huh ???
72 CustomCamper's Avatar
How about bringing the burb when it's finished? I had my blazer in it this month. The cruise in is once a month so you have some time to get it fixed...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 05-09-2008, 04:49 PM   #28
87 dually burb
my short bus
give me some info on the cruise in
thanks I dont know about finished but
I'll drive it when I finish the brakes next week
Old 05-09-2008, 08:44 PM   #29
72 CustomCamper
huh ???
It's the first Saturday of every month at A-1 Speed and Custom near the corner of Butler Rd and Chatham Heights Rd. It starts at 5pm. and runs until ?
Chuck
Old 05-09-2008, 08:47 PM   #30
87 dually burb
my short bus
cool 5 min from my house
hope to have it dropped and patch up some body work
before june
I'll be there
Old 05-09-2008, 08:51 PM   #31
72 CustomCamper
huh ???
Cool, look for the big silver and blue blazer. That's my truck...
Chuck
Old 05-11-2008, 10:20 PM   #32
87 dually burb
my short bus
what to do??
stylintrucks has the djm 5"/5" drop kit for
$356 now
may skip body work and drop it this month
Old 07-05-2008, 01:10 AM   #33
87 dually burb
my short bus
flipped the rear got about 8"s from it
got approval too
rub the dually fenders but I can trim for that going to add 2" blocks to get my dropped height
will run helper bags for ride height
pulling front springs out to measure some thing going 3" spidle with bags in front truck may sit for few weeks before I get back to it
got free 93 yota 2wd to drive so I can bag the burb now
any thoughts or comment on best front setup??
spindles = djm
bags = ??
just going to run a basic air line for now I have 2 40 lb co2 tanks for air
so have to work that in later
Old 07-09-2008, 10:44 PM   #34
87 dually burb
my short bus
dropped front (pulled spring and bump stops)
about 2" to fender well rub at full lock on steering
still going to add 3" djm spindles
rear back on stands added 3" blocks
trimming fender wells and dually flares where it rubs
found this while trimming today
#4 rebar wrapped in bondo and paint stirs
will be back on wheels tomorrow for more measuring and a pic or 2
I flipped my rear with new perchs so when I get ride height close I'll set pinion angle than hopefully next week I can pull in back up the driveway LOL
Old 07-10-2008, 09:25 AM   #35
tvblazer78
Low & Fast!
tvblazer78's Avatar
That looks sweet!! get us some pics with it back on the road..
tvblazer78 is offline   Reply With Quote
Old 07-10-2008, 09:45 PM   #36
87 dually burb
my short bus
back on ground with 3" blocks and centered wheels in well moved axle back 1.5" only got 1.75" drop from the block cause axle is out of the lowest part of arch now
front thinking of cut the plate on the front control arms that held the bump stops should get 1.5" drop with 1" bump stop to rest on when aired out
but it has the steering stops on it any thoughts?
next week going to remove inner fender wells and start relocating stuff
when finall drop is set will redo wells then
will order spindles next month along with front bushing kit
Old 07-11-2008, 03:47 AM   #37
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
man, a burban rocks, but you throw on a set of duals, and you got the prfect truck, well next to a crew cab.. always wanted one lke this.. looks great...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-11-2008, 08:40 AM   #38
tvblazer78
Low & Fast!
tvblazer78's Avatar
You will be ok with out the steering stops, when you tune it lock to lock just take it easy on it.. And that thing looks good..
Old 07-11-2008, 07:09 PM   #39
87 dually burb
my short bus
that what I was thinking cause most drop arms I didn't see any
biggest issue I've had to deal with is that the frame is off set 1" to passenger side would guess for spare tire location
so going to cut brackets off and set bumpstops in place this weekend
this will level it out for now but will rub fender well in front
tvblazer78 what is you front setup??
any pic's up and down with out wheel for reference thanks
Old 07-12-2008, 10:05 AM   #40
tvblazer78
Low & Fast!
tvblazer78's Avatar
Here ia a older pic, the only thing that i have changed is cut the cup for the bags 1". I have 3" belltech spindles and cut all the stops off. Hope this helps.
Old 07-12-2008, 03:05 PM   #41
87 dually burb
my short bus
what is the amount of lift you get from that?
Old 07-12-2008, 04:49 PM   #42
tvblazer78
Low & Fast!
tvblazer78's Avatar
About 6"-8"
Old 07-13-2008, 01:55 PM   #43
87 dually burb
my short bus
what would be the issue if you cut 2" out of the lower cup besides droping in a 1" when aired out
until I get my spindles on and cycle my suspension then see what hits
going to notch the frame rails now before they get in the way
think I'm going to lower the toy now just for fun
gotta love torsion bars and axle over rears
Old 07-13-2008, 02:27 PM   #44
tvblazer78
Low & Fast!
tvblazer78's Avatar
The thing that you have to look out for is if you cut to much you may have a bag hitting something on the A arm.. So do some test fits first..
Old 07-14-2008, 12:38 AM   #45
87 dually burb
my short bus
going to be a month or two for spindles and bags
got side track today and was lookin for mirrors found a set I liked on a seadoo jet ski got 2 pic's will post monday
going to remove stock mirrors,all dr handles,dually flares,tail lights,rear bumper and hitch
hope to get some welding done next week
roof rack holes need redone
fill in some holes mirrors,tail lights filler,dr handles
and all drip rail hole's about 100 of them
redo visor or just remove unsure yet
Old 07-14-2008, 11:40 PM   #46
87 dually burb
my short bus
also going to cut out rear flooor and notch frame 2.5-5"s what ever is need to bottom out flare in rear
cause when I notch it I have no place for exhaust,fuel line or ac line
I guess next week or 2 will be mostly tear down and removing every unwanted piece on burb
(*(*( phrase of the day )*)*)
the lower i get the more I have to cut out to get there
Old 10-22-2008, 10:06 PM   #47
87 dually burb
my short bus
got a little side track lately
and bought a 90 sle burb for a DD
$500 craigslist find loaded
also bought a rust free 88 3/4 2wd burb
complete minus 7.4
the more I looked at the 87 the worse the body is
late fall going to strip down the 88 for a "z"
and rear notch/raised floor/par 4-link
pic to come end of month when I line them all up in driveway(lol)
Old 01-08-2009, 10:33 PM   #48
justpball
justpball's Avatar
new pics bro!?
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Thread Tools
Display Modes
