Old 03-26-2008, 12:59 AM   #26
tds
Re: what size are n2trux wheels?
Ill have to break out the square and pull off the rear tire. 10"s wide with 6"s of back spacing means the rim should only come out 4 inches at the mount correct?
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 03-26-2008, 01:28 AM   #27
lolife99
67-72 parts collector,…
lolife99's Avatar
Wrong. If you measure a 10" rim from the outside edge to outside egde,... the rim will actually measure 11". Most people forget that the actual 10" is measured from "tire bead surface to tire bead surface". So from the rim out,... it would measure 5". I know this is confusing. The best choice it to take a bare rim, (like a 15x8 ralley) and measure off of it. A 15x8 rally has a 4" BS. So if you want you rear wheel to be 10" wide,... add the extra 2" where it will fit best. This could be 1" on the outside and 1" on the inside. Just put the rim where you want it. On most billet wheels "THE CUSTOMER" has to choose the wheel backspacing.
Keith
Convert to disc brakes.
Old 03-26-2008, 01:44 AM   #28
tds
So with the tire sidewall I should go on the safe side and measure 5.5 from the mount. I really don't wanna toss a bed side. Ill have to measure a few times and measure the shallowest part of the bed side. Thanks for the help guys.
1981 - C-10 SCSB
Old 03-26-2008, 05:30 PM   #29
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by SCOTI View Post
Ken, you know me well enough to know I won't say something unless it means something.
Keith will tell you I'm the numbers guy when it comes to this stuff & based on my BS for the 74 I know the 9.5's w/6.00 does not seem correct. If it does have 6.00 BS the wheels would be tucked farther up in the well; instead both our trucks look very similar from the side view.
Scoti, you are the dude when it comes to remembering tire/wheel sizes and backspace. My comments weren't targeted at you, or anyone in particular. Just trying to clarify why I posted the specs as I did.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-26-2008, 05:54 PM   #30
SCOTI
SCOTI's Avatar
I understand. I was just keeping everyone on the same page as to why I was piping up about the back-spacing on your wheels.
I'm sure some who don't know us are asking themselves "who is this guy that thinks he knows what another guys truck has/doesn't have.....".
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Thread Tools
Display Modes
