Old 04-01-2008, 06:22 AM   #26
Sicmaro
Always wrenching!!
Sicmaro's Avatar
Re: 5.3L...... which manifolds???
Originally Posted by Hart_Rod View Post
Here's some information on the factory manifolds that Shifty posted (pic included):
The set of ’98 Camaro/Firebird manifolds (top) worked best for us (PN 12567706 RH, 12559507 LH). Other possibilities include ’99-’03 Camaro/Firebird (second from top), ’99-’03 C/K Silverado (second from bottom), and ’97-’03 Corvette (bottom). These manifolds have 2 1/2-inch outlets that Cole was able to build a complete exhaust off of.
Ive got all 3 of the pictured ones except the top set (98 Camaro)
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 04-01-2008, 06:44 AM   #27
Hart_Rod
Hart_Rod's Avatar
Those are the ones I have (98 Camaro) and they fit without any interference.
Hart_Rod is offline   Reply With Quote
Old 04-01-2008, 07:22 AM   #28
gringoloco
A guy with a truck
gringoloco's Avatar
The '98 manifolds should work. You can also try switching to the 73-87 style motor mounts, which is what the ECE kit is based on. This will buy you the clearance you need at the mount- they do not have the 'hump' that is causing you problems...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-01-2008, 07:38 AM   #29
shifty
Questionable
shifty's Avatar
What he said ^^
The ECE mounts use the standoffs from a 73-87 pickup. ECE custom-fabbed the top plate so it would adapt the 73-87 stands onto the GenIII engine, and, honestly, you could probably just take a F-Body top-half of the engine mount and bolt it directly to the standoff of a 73-87 truck mount. The only thing is, if you're running a 67-72 pickup, you will need to drill four holes in your crossmember to get the 73-87 mount to work (on the 73-87 trucks, the framerails are 0.5" taller, so ... the 73-87 mounts sit differently.)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-01-2008, 09:16 AM   #30
Deuce
Deuce's Avatar
Here's a set of Doug Thorley "proto-type" headers that I'm test fitting on my 69 Suburban (5.3/4L60E). They fit great and should add some decent horsepower. I'll probably run the 98-00 F-body manifolds on my 67 CrewCab since it's not going to be a show truck. I've got an extra set if decide to go that route.
Can you buy those yet?? How much??
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 04-01-2008, 10:31 AM   #31
Sicmaro
Always wrenching!!
Sicmaro's Avatar
thanks for all the help guys!!! I did a lil work to the mount, got the truck manifolds to fit. Not trying to spend alot on this truck, just want a nice driver. i got the maro for show and go. thank again for the all the info.
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 06:34 PM   #32
shifty
Questionable
shifty's Avatar
I PM'ed the Thorley guy here at the forum what seems like a week ago, and still haven't heard anything back. I don't think they're for sale.
Old 04-02-2008, 02:46 AM   #33
68 short step
yes you can... call them, they are 550$. that was the quote i got..
68 short step is offline   Reply With Quote
Old 04-02-2008, 07:58 AM   #34
shifty
Questionable
shifty's Avatar
Wow, I guess Thorley doesn't want my business, then. That's unfortunate.
Old 10-07-2008, 01:30 AM   #35
Ford Assassin
Ford Assassin's Avatar
Digging up an old thread....
I have '98 F-Body manifolds for my 5.3 swap that is nearly finished. I was wondering where you guys bought the exhaust flange that bolts to each manifold and connects with the rest to the exhaust? I plan on fabbing my own exhaust in my garage and these are the only pieces I am having trouble locating.
The pattern is different from one side to the other.
Thanks guys!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 10-07-2008, 08:11 PM   #36
Custom 68
Custom 68's Avatar
I used the ls6 manifolds which are some different I am sure but I was able to get a header collector kit the one with the flange and marked and drilled them to fit. I just hooked up my pipes to this collector tube
may not make sense...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-14-2008, 04:06 PM   #37
brossow
Amateur Rust Fighter
brossow's Avatar
Exclamation Corrected info
After a lot of research and discussion and money almost thrown away needlessly, I really feel I need to correct the info above.
'98-99 F-body exhaust manifolds are identical. They changed for '00-02 and there was no '03 F-body. The part numbers for the '98-99 manifolds are not those listed above (which are for '00-02). The correct numbers are 12560193 (RH) and 12560194 (LH). (The RH manifold for '00 changed again for '01-02.)
Part number info is from LS1Tech: http://www.ls1tech.com/forums/showthread.php?t=336981
Wanted to get this out there before someone else had to go through what I did just to find out he already had what everyone was trying to tell him to get (and they don't fit anyway). This isn't a slam on Rob or Shifty by any means -- just want to get the correct info out there for others.
Brent
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 11-14-2008, 05:29 PM   #38
grancuda
grancuda's Avatar
I am planning on doing a 5.3L/460LE swap this spring/summer. I was going to just put a 700R4 in and then put in a 350 but at a local salvage yard I can get a low mileage 5.3L/460LE w/ computer and wiring for $1,500 so that is the route I want to go. Do you have any advice about the swap or good sources of info about it?
grancuda is offline   Reply With Quote
Old 11-14-2008, 08:52 PM   #39
Kid
Kid's Avatar
grancuda, LS1Tech.com is great for info. go to the "conversions hybirds" thread. That site was where I got all my questions answered during my swap. (5.3/4L60E in 51 GMC). youll love the performance of the 5.3!
Kid is offline   Reply With Quote
Old 06-14-2009, 10:52 PM   #40
jakeshoe
I tried to use the 98-99 F body manifolds on my 5.3 swap last week and the right side will not clear the stock mounts.
I guess the ECE style mounts are required to use a stock type manifold.
jakeshoe is offline   Reply With Quote
Old 06-15-2009, 11:54 AM   #41
Ford Assassin
Hey Jake, looks like we are both on Team Chevelle, HybridZ, and LS1Tech.
I ended up modifying a set of long tube headers intended for a '98-'02 F-Body.
However, my '98-'99 F-Body stock manifolds also worked with my setup. I used Brother's tubular engine stands that are intended to allow folks to use a '68-'72 Chevelle motor mount with a regular SBC/BBC. So I used those to replace my factory SBC frame mounts, then I bought a $50 kit from Summit made by Trans-Adapt that is a pair of steel plates that adapt the 4 bolt LSx motor mount pattern to the SBC/BBC. The kit even came with '68-'72 style Chevelle motor mounts.
So was able to get all my LSx mounting hardware without fabbing a single thing and for less than $200. Plus it places the motor much more to the rear compared to the ECE kit.
Cable
Old 02-18-2013, 06:32 PM   #42
68chvy
Originally Posted by shifty View Post
'98-00 F-body manifolds. Fit for me without grinding.
What motor mounts did u use? And what e fine stands do u have? Pics?
68chvy is offline   Reply With Quote
Old 02-18-2013, 08:59 PM   #43
Hart_Rod
Hart_Rod's Avatar
He used ECE motor mounts and stands.
Old 02-18-2013, 10:20 PM   #44
BionicABs1
I have trailblazer SS manifolds on mine
BionicABs1 is offline   Reply With Quote
Thread Tools
Display Modes
