Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-09-2008, 01:14 PM   #26
nxtruck
nxtruck's Avatar
Re: Me making a motor hit
Gotcha. I think you'll be right in the thick of things with the bigger motor. Sounds cool that you guys can throw your money in the pot and run the "king" and, if everything goes your way, take home the title AND some money.
As far as going to a 400, I'd think that you're better off staying with the 350 block and doing a 396. I'm running a 400 block and I realize that it won't last forever. In my humble opinion, the 350 blocks( especially the 4-bolts ) are a little stronger than the 400 stuff. Probably not a big difference in strength, but when you're spraying, every little bit helps.
Hang tough down there: it sounds like Ike will go further south than where you're at. Hopefully it stays on that course. Stay safe...
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 09-09-2008, 06:05 PM   #27
hotrod 80
mini truck racer
hotrod 80's Avatar
I had all these parts before this class came along and you are completely correct . If i had it to do over i'd go LS series motor . You get a good head and could build a close to 410 shortblock .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Thread Tools
Display Modes
