12-16-2008, 11:18 AM | #26 |
Re: Stainless plumbing
Yes but from what I have read you cannot double flare stainless due to the material work hardening. Thus the 37* single flare and AN/JIC fittings.
12-16-2008, 11:56 AM | #27 |
12-16-2008, 12:05 PM | #28 |
It'd be alot cooler if you did
I would agree with the proper tools. I tried (just for the heck of it) to put a 45 degree flare on a piece of my 3/8 tubing while I was waiting for my flaring tool to come in. The cone did nothing but push the bar (clamp) right off the tubing.
12-16-2008, 01:45 PM | #29 | |
Annealed tube is treated to make it softer so that it can be flared. Also you should cut the tubing with a cutoff wheel, not a tubing cutter. A tubing cutter will "work harden" the end of the tube, especially if the cutting wheel is dull. You should also debur and chamfer both the inside and outside of the tube prior to flaring. It also helps to put the tool in a vise. |
12-17-2008, 10:31 AM | #30 |
12-17-2008, 05:53 PM | #31 | |
12-17-2008, 08:50 PM | #32 |
sharp as a marble
The Couplers are all stainess. They consist of a nut and ferrel ( sp ) it is no different than the brass ones you can get at the hardware store. Except that the ones I bought were rated at 10,000 psi or something crazy like that. They can be loosened and tightened if you need to. My Chevelle was a carbbed car, and never had a leak. I used a couple of short pieces of their push lock hose without clamps. I would use this stuff again! Made me a bit nervous, but I saw my ex girlfriend about a month ago, and she was dry as a bone. The new owner loves my Chevelle. HE SMOKES IN HER!
12-20-2008, 06:13 PM | #33 | |
http://www.mrosolutions.com/piselret.htm#sol34 |
12-24-2008, 12:44 PM | #34 |
I double flare stainless... It IS a *****, but it's made a lot easier if you put a really substantial chamfer on the end before you bell the line.
tutorial? your flare tool should com with instructions. source: I buy 20' lengths from InlineTube.com they also supply me with all my brass fittings. they also sell those stainless hold-down clips that someone asked about. I have a big bag of 1/4 and a big bag of 3/16 (holler if you wanna buy some)
RN U OVR |
12-24-2008, 03:42 PM | #35 | |
12-24-2008, 03:48 PM | #36 |
in a BIIIIGGGG box!
no $hit. it's like 16x60" and the tube comes in a big oval coil. p.s. Schenectady is gross Where you at in Johnstown? I'm dating a girl from Fort Johnson.
RN U OVR |
12-25-2008, 06:12 PM | #37 |
OG
Question, I went on there website but didint see where I could choose the tube I wanted. Im trying to get 1/2stainless tube for my air ride but didint see it could you point me in the right direction?
12-26-2008, 09:40 AM | #38 |
Dude, 1/2 stainless is WAAAAAAAYYYYYYYYY overkill. You are just going to cost yourself more money in fittings for no reason. I'm running 1/4 stainless based on Porterbuilts recommendation.
Thread Tools | |
Display Modes | |
