12-04-2008, 04:16 PM | #26 |
Parts and more parts
Re: L460E questions
IF ALL ELSE FAILS Street and Performance sells a tranny tailshaft housing that allows for BOTH the electric computer drive and a gear drive for your speedo. I have seen them installed in the early Chevy trucks with late model EFI engines in them. Your tranny guy is behind the times on this one. It is not cheap, but it does exist. Also--have you considered aftermarket gauges and along with that put in an electric speedo and run it from the 4L60E output? There are more than one way to skin a tranny.
12-05-2008, 08:20 AM | #27 |
Re: L460E questions
Man theres alot of info on this forum! Where will be the best place to take my truck to get the computer reprogramed, egr deleted, and performance tune, and what does that usually cost. I have little experience with efi, and I know I'll learn alot before this one is rollin!
12-05-2008, 11:09 AM | #28 |
Vortec in the works
Re: L460E questions
http://www.speedscenewiring.com/
I've talked to these guys and they can rework stock harness and computer to what ever specs you want for around $450-600 depending on what you want
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
12-05-2008, 11:37 AM | #29 |
Re: L460E questions
Another wiring and EFI expert is Mike Noonan at EFI Connections. He does a lot of rebuilding of wiring harnesses for shops all over the country.
www.eficonnection.com |
12-07-2008, 10:12 AM | #30 |
Vortec in the works
Re: L460E questions
Other than removing the anti theft from the computer,could you use the stock harness as is?
12-07-2008, 11:04 AM | #31 | |
Local Detroit diesel nut!
Re: L460E questions
Mike
Nothing cool anymore, I am old and boring.... |
Thread Tools | |
Display Modes | |
