Old 01-13-2009, 08:33 PM   #26
andrewmp6
Re: For all who want to do a LSX trans plant.
The distributor kit mounts it to the timing cover like a old mopar since the block was not set up for one.
andrewmp6 is offline   Reply With Quote
Old 01-14-2009, 05:47 PM   #27
kevinr1970
If a person was going to convert one of these engines over to a carb'd setup, why wouldn't you just buy a set of aluminum heads for an older engine?
Seems that by the time you gathered all the parts to do the swap for an LSx, you could have built a stout carb'd SBC with aluminum heads? All the periphery parts (headers, starters, etc.) sure seem a lot cheaper for a SBC too.
Plus the parts changing later on down the line would be simpler (not the physical part, but finding the right parts when needed).
Don't get me wrong, I love the little 4.8 in my '06 and I keep telling myself a 5.3/4l60 is in the future for my K5 2wd. But it seems if you aren't going to keep the FI you could come up with an equal SBC.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-14-2009, 09:13 PM   #28
BigBlocksRule
The 12* and 15* valve angles of the LS engine family and symmetrical heads make a good bit more power per cube for comparably built engines, as compared to a conventional smallblock. I've watched an L92 headed 6.2L block based 427 stroker make 630hp with a hydraulic roller cam that sounded bone stock. MSD makes a system that works great with carb'd LS engines, and you can use remote coil packs to make it look better.
I'll still take a big-inch big block, the LS stuff can't touch the torque of a 540+ big block with decent heads. Plus, in a few years, the LS stuff will be everywhere, just like the old style smallblock is now. A big block will still be more impressive under the hood of pretty much anything.
BigBlocksRule is offline   Reply With Quote
Old 01-14-2009, 11:12 PM   #29
andrewmp6
The ls has a lot of things over the older small blocks.Like the oil pan is structural oil pump is in the front of the engine like a import.The intake is dry no coolant in it so less likely to leak there.They are alum they weight less there is a big list why to use one carbed or efi.
Thread Tools
Display Modes
