#26 |
![]() Join Date: Jan 2007
Re: Parts from a parted 70 C20
#27 |
#28 |
timzrides: PM sent
#29 |
White wall terror
If the switch worked good when you pulled it I'll take it. The problem with mine is when you turn on the wiper the washer pump comes on too, If this one doesn't do that consider it sold. Pm me with your info and I'll send the money out right away. Thanks Mark.
#30 |
PM sent
#31 |
I got the hinges. Thanks a ton for shipping so quickly, and for a good price.
Horsepower sells cars Torque wins races |
#32 |
The bumper is sold to timzrides.
#33 |
#34 |
White wall terror
the money order was sent.
#35 |
#36 |
I'm interested in the drive shaft as I'll be converting over to a 700r4 in the near future, how much would in be to ship to 78664?
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
#37 |
Just to let you know, these driveshafts will only fit on a C20 with a dana 60 rearend as the rearend is bigger than a 12 bolt. If you still want a quote, I will have to weigh them. Thanks and let me know. David.
#38 |
Thanks for the info, mine is a c10 with the 12 bolt, so this drive shaft wouldn't work for me.
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges Last edited by wHATANERD; 02-27-2009 at 08:04 PM. |
#39 |
Automatic column linkage that is not complete. $20 plus shipping.
#40 |
White wall terror
I got the wiper switch today, Thanks for the speedy delivery. I would definitely buy from you again, Thanks again Mark.
#41 |
#42 |
![]() Join Date: Jul 2004
i need the under dash harness how much for shipping to 29204, any problems with the harness that you can see.
thanks, chris |
#43 |
The only thing wrong with the harness is that the ignition plug is melted. It is about half gone, but you can still plug the wires into it. It also does not have the wiper switch included. I need to get a weight on it first, which I will do in alittle bit. I'll let you know. Thanks. David.
#44 |
#45 |
If someone buys the gas tank, it has about 2 or 3 gallons of 93 gasoline in it and you can have it with the tank.
#46 |
gotta pass on the harness i really need the ignition plug mines toasted.
thanks though, chris |
#47 |
#48 |
is the wiring harness still available and dose it have the harness for the heater fan switch?
#49 |
Yes the harness is still available. The heater fan switch harness is part of the underdash harness and yes, it comes with it.
#50 |
"the other guy"
would you do 65 shipped for the 6 cyl radiator to 95901? thanks
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Thread Tools | |
Display Modes | |
