Old 02-27-2009, 10:31 AM   #26
Storm Chaser
Storm Chaser's Avatar
Re: quad carb
There is nothing cooler sounding that a properly tuned and jetted 795 quadrajet that's wide open.
Sure there is- a triple deuce with all 6 barrels wide open.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 02-27-2009, 10:43 AM   #27
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
Re: quad carb
now will a rebuilding kit bring a old non used carb back to life
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 02-27-2009, 11:32 AM   #28
Storm Chaser
Re: quad carb
It should, assuming none of the parts are warped/cracked/damaged.
1988 R2500 Crew Cab
Future plans-
Old 02-27-2009, 12:09 PM   #29
pokethesmot
Re: quad carb
man i give up on this carb thing i cant even take it apart i fail at life lol
Old 02-28-2009, 03:37 AM   #30
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: quad carb
hmmm...
well.. there's q-jet books avail online..
maby someone will linky or email you one =-)
i dont have any but do some searches
like "quadrajet .pdf" get nerdy and creative youll be surprised to see what id FREE on the internet
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-28-2009, 05:28 AM   #31
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: quad carb
It's too bad you live that far cause I would rebuild it for you.
If you're going to try and seal it up, clean the leaking area first, then paint
nail polish over the spot and let it dry a little while.
Sillycone will never ever seal up gasoline leaks.
heavychevy79 is offline   Reply With Quote
Old 02-28-2009, 06:29 AM   #32
79blazer
79blazer's Avatar
Re: quad carb
Originally Posted by dammitmitchell View Post
if youare "in good" with your napa or carquest guys..
there's a noticible amount they can take off the price for you..
mybuddy got his for 10 bucks more then a q-jet..
but.... we spend.. ahem... alot of money there..
I had an old holley that was off a old 60's flatbed 2 ton farm truck. I traded it and a few dollars for a mint rebuilt 800CFM quadrajet with a guy who works at Autozone who had it on a Chevelle 2 years ago.
For gas mileage get a 750CFM one off a car. The primaries are smaller, allowing more airflow velocity which is best for low- midrange torque and mileage. The secondaries are vacuum operated, and only open as much as needed. All of which is the beauty of the Quadrajet. No adapter or transmission bracket needed.
Out of all the carbs you have, is there at least one that is usable as is? At least for now?
Quadrajets are application specific (jets and rods, etc) so if you have a 350, use a 350 carb and it should be close enough. The 170 series 77-80 are best.
If you love taking things apart and seeing how they work, you'll like the quadrajet. Get the book "Rochester Caburetors" by Doug Roe, it is, the quadrajet bible.
I used to run a 1406 edelbrock on my Caprice. It is so simple, like a lawn mower carb. It is literally plug and play, except you need an adapter and trans bracket. Buying a tuning kit is cheap and easy to work with. But it costs about the same as 5 q-jet rebuild kits. For a novice, the Edelbrock is better. But the quad really is more of an advanced carb, in more than one way.
79 Blazer Cheyenne, 2wd 305 3.42 stock
85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks,
79blazer is offline   Reply With Quote
Old 02-28-2009, 08:45 AM   #33
78 Chevyrado
Re: quad carb
or a Chevy 409 with dual AFB's running down the drag strip
78 Chevyrado is offline   Reply With Quote
Old 02-28-2009, 08:56 AM   #34
ont_guy_38
ont_guy_38's Avatar
Re: quad carb
Nothing wrong with a quad on a basicially stock motor,at first they are very confusing but take pictures with a digital camera as you take it apart and this website has a lot of info http://www.florida4x4.com/tech/quadrajet/
ont_guy_38 is offline   Reply With Quote
Old 02-28-2009, 10:07 AM   #35
pokethesmot
Re: quad carb
well i got the carb working i guess it was just a tiny gas leak the whole time and thanks heavy Chevy
Thread Tools
Display Modes
