Old 03-31-2009, 01:52 PM   #26
78 Chevyrado
Re: Horrible gas mileage
You can't go by the guage as said above, you have to compare mileage to how much fuel it takes to fill it up. for example, I have a 20 gallon tank and when I get to E on the guage I still have 6 gallons left. Also when full it goes past the F on the guage but it only takes 4 gallons to get to the 3/4 full mark.
The point of having a dual spring is that when the spring you have fails eventually, the truck will be floored possibly causing an accident until you get a new spring. with dual springs when one breaks, the throttle will still go back closed and you can get it home.
78 Chevyrado is offline   Reply With Quote
Old 03-31-2009, 01:54 PM   #27
enaberif
Makes sense.
Tho looking at pictures am I the only one thinking this motor has had some work done to it?
That isn't a stock intake manifold nor are those stock heads.
enaberif is offline   Reply With Quote
Old 03-31-2009, 02:12 PM   #28
Rain City
The black hose you pointed out connects to this strange metal cone shaped thing...
The intake is a Edelbrock Air Gap Intake manifold (If that helps?) not sure the specifics of the holley carb...
Rain City is offline   Reply With Quote
Old 03-31-2009, 02:19 PM   #29
enaberif
That weird can is the vac advance which allows for adjustment of timing for better mileage at part throttle.
Try to find some numbers on that carb and write them down.
I'm talking about the big fat one not the little skinny one. The one just to the right of your distributor in the first pic on this page.
Old 03-31-2009, 03:03 PM   #30
Rain City
OK so I guess I am a little unclear...
So the right PCV valve will be according to my engine, or to the model carb?
And if I don't have one, then where does it go and what is there now?
I'm a dummy.
Old 03-31-2009, 03:07 PM   #31
enaberif
Where does the hose in the picture go to?
Old 03-31-2009, 03:14 PM   #32
Rain City
Goes here...
Old 03-31-2009, 03:22 PM   #33
Adams74Chevy
Adams74Chevy's Avatar
Originally Posted by Rain City View Post
Goes here...
That's the vacuum line for the power brakes booster.
Adams74Chevy is offline   Reply With Quote
Old 03-31-2009, 03:24 PM   #34
enaberif
Ok so that is going to the brake booster.
Now you need to track down the numbers on that carb so you can find out what one it is exactly so you can find out where all the vac sources and what they do are located.
You need to make sure where that line is hooked to the carb is for the brake booster or for something else. If it is for the brake booster I do not know what that small can is.
But to hook up a pcv valve properly you may need to put a "T" into that line to run another line to the pcv valve which would go where the breather is in the left valve cover.
Old 03-31-2009, 03:36 PM   #35
impalamark
impalamark's Avatar
I'm concerned about the "RANDOM HOSE " you referred to
it could be a transmission cooler that was abandoned
look for a small cooling coil [radiator like device wired or strapped
to the radiator} if that's what it is it would have had two hoses like that coming out of it. if both are disconnected it's ok to leave as is
these lines again should run toward the front of the truck toward the radiator
if it comes from the rear of the truck along the frame rail it could be part of the fuel system/emissions system or even a dual tank set up . find out where
and let us know .DO NOT just cut it out as previously suggested
MArk
the avatar was my 62 I owned for 27 years
84 chevy short short bed black
84 gmc long bed copper/ buckskin
88 chevy k5 blazer white
Life's short make the most of it
Mark aka impalmark
impalamark is offline   Reply With Quote
Old 03-31-2009, 07:35 PM   #36
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Ditch the aftermarket springs. Yea, the throttle will be hard to push with two springs. Locate some factory style springs. The are lighter and coiled together.
Original GM parts are available at http://www.montemania.com/genuinegmp...under_hood.htm
You can move it closer to use dual aftermarket springs. http://www.rjays.com/Lokar/lokar_images/SRK-4000-lg.jpg
You can use dual springs on the other side. http://www.mustangsplus.com/images/13213demo.jpg
Another option: http://www.hspnnews.com/images/uploads/QFT_spring.jpg
gchemist is offline   Reply With Quote
Old 03-31-2009, 07:36 PM   #37
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
The random hose is for a 3 line fuel pump(return line) Don't sweat it just plug it.You do need the PCV(Positive crankcase ventilation) valve.too much crankcase pressure will start leaks and just makes a mess.pcv valve can be in either valve cover just needs a 3/8 vac hose to manifold vacuum.look for a plug behind the carb in the manifold.parts store will have fittings to screw in the manifold to and hook a hose to.put the pcv in place of one of the breathers.More than likely the rubber grommet that secures the breather will be too large for the pcv and you will have to find one to fit correctly
powerdriver 1958 is offline   Reply With Quote
Old 03-31-2009, 07:41 PM   #38
enaberif
If you look under the air cleaner the manifold port seems to be on the #8 runner.
But its why I wanted him to find out the model of his carb. I know with the old qudrajets they had a spot for a PCV valve so I was thinking maybe that one the brake booster is using it for that... but its hard to say.
Old 03-31-2009, 07:56 PM   #39
powerdriver 1958
Kid's Mechanic
usually the port his power brake vac is on I use for the PCV valve and the port in back of the carb for power brakes just to keep the hoses short and justs looks better.
Old 03-31-2009, 08:44 PM   #40
powerdriver 1958
Kid's Mechanic
now for the mileage.Is this cammed up?rough idling cam can be for performance and be hard on mileage,the Vacuum Advance Chamber you have asked about in your picture could cause it.Have you noticed black smoke on acceleration?carb can be over fueling.With a Holley carb there is a part called the Power valve that can cause poor mileage.most Holley's have external adjustable floats and could be set a little high. have you checked the engine timing? Sorry about so many questions but there are quite a few things that affect fuel mileage.
Old 03-31-2009, 08:46 PM   #41
enaberif
I'd assume since the truck looks like it has different, heads, intake and carb that this motor has had some work done to it and I can't see someone putting that much effort into this truck and not put a new cam.
Old 04-01-2009, 02:23 AM   #42
Rain City
Yes it does have cams... the PO wrote down what kind they were (would have to find it) but I remember he wrote (for torque).
I will take a look at the carb tomorrow... unfortunatly I have to work - today I got sucked in to the truck time-abyss haha- know what I mean??
Old 04-01-2009, 02:52 AM   #43
enaberif
Between the truck having a aftermarket cam, carb, manifold and heads.. I personally don't think mileage will there for you.
But the carb numbers will help.
Old 04-01-2009, 12:40 PM   #44
Damien
Damien's Avatar
The PVC valve can go in either valve cover. Everyone says the right side because that is where they are stock. The PVC helps remove combustion gasses (blow by) that have pushed the piston rings and will contaminate the oil and shorten engine life.
Assuming your truck has a 16 gal tank and you fuel gauge and Speedo are correct, which they probably are not. You would be getting about 6 mpg. If the miles are mostly in town, the numbers are not that far off (IN MY OPINON) of what they should be by looking at your engine set up.
You still have not said if the miles are city or high way and we do not know what the gearing of the rear end is.
Mythbusters tested a newer trucks designed with the help of a wind tunnel. Our trucks were not designed in a wind tunnel. I think they would have had different results if they tested a vehicle with the aerodynamics of a refrigerator.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 04-01-2009, 01:56 PM   #45
Rain City
Will the PCV Valve even help my gas mileage?
The miles were highway...
I think I will do what someone had suggested and get an ACTUAL mpg by fillling the tank and running it till its empty.
Old 04-01-2009, 03:07 PM   #46
88 Dippy
88 Dippy's Avatar
the unknown hose looks like it whent to the long gone charcole canister for the EVAP system
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
Old 04-01-2009, 06:21 PM   #47
Rain City
OK so I'm pretty sure this is the carb...
http://www.holley.com/types/Street%2...raditional.asp
The only real number was this
thoughts?
Old 04-01-2009, 06:31 PM   #48
enaberif
Pull the air cleaner spacer off and look at the front of it behind where the air cleaner spacer was.. should be numbers there.
Old 04-01-2009, 07:00 PM   #49
Rain City
Here she is...
Looks like 1850-5, 1564
Changed my spark plugs today BTW... man that was not very fun.
Old 04-01-2009, 07:12 PM   #50
enaberif
According to holley its a 600cfm carb but I don't know what the 1564 means.
Doing a search on google.. most people say those 1850s are junk so I'm not sure.
And yes where that large hose is coming from it the Brake Booster/PCV connector.
So go pickup a pcv valve for your truck, a "T" for the line, some extra hose and hook it up.
Thread Tools
Display Modes
