Old 06-28-2009, 07:58 PM   #26
lokeondubs
1981 CHEVY C10
Re: JUST A FEW PICS OF MY ENGINE.under construction
Originally Posted by CoggedBelt75 View Post
I have extended alot of the wires and ran them thru the passenger side of the firewall and back out at the far bottom corners then passed thru the cut outs in the fenders and along the inside of the frame rails, all wrapped in
convoluted tubing. Took awhile, but pleased with the results. Also went with
Billet Specialties spark plug wire looms so less wire was exposed. Once you give it some thought and a little work, your compartment is going to look great. Be sure to post some after pics.
dats nice,,what paint do u use flat black??Is it hard to crimp those wires,,what kinda wires to get?under header fit wires or custom wires
1981 C10
lokeondubs is offline   Reply With Quote
Old 06-28-2009, 08:26 PM   #27
N2TRUX
Happy to be here
N2TRUX's Avatar
Do not use flat black. It will stain easily and absorb moisture. Use a satin or egg shell black. Gloss black is fine for parts that can be sanded and painted properly only.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-28-2009, 08:29 PM   #28
lokeondubs
1981 CHEVY C10
ok,,man help me out,what wires to get to cut ?custom.I work on cars also.but just want my wires hid..my wife hate it.She not on road yet but will be after exhaust.Im ordering flowmasters mon
1981 C10
Old 06-28-2009, 09:47 PM   #29
383Ram
383Ram's Avatar
Yea, satin, or semi-gloss flat black is what you want for paint. Flat stains, mars, attracts dirt to easily, and gloss shows everything--dirt, scratches, etc--you don't want either one of those.
As far as wires, you need to get the make your own kind. They typically have the spark plug side already made with either straight boot (180 degree), angled boot (45 or 135 degree) or right angle (90 degree). You need to crimp on the distributor socket and slip the boot on. Its the only way to go when dealing with custom applications such as going through special looms or trying to hide them going under the headers or what not. Making them is like any other wiring project, it takes time. If you do these, i suggest getting a set of wiring crimping plires that are made to do plug wires or have the option to.
454/4 speed, '85 Dodge Ram hybrid build in progress
454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track
Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050
Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289
383Ram is offline   Reply With Quote
Old 06-28-2009, 09:55 PM   #30
383Ram
383Ram's Avatar
Originally Posted by lokeondubs View Post
I want to paint the engine compartment silver in future.Im painting it same color as my charger.I posted pics last week
Sorry, i didnt see that before. Why not paint it now and fix the wires at the same time? If not, just get the black loom and clean it up best you can. If your painting it silver, any automotive type paint will do--even a gloss is fine. I just don't like gloss black on an engine compartment because its hard to keep clean---just like the outside of a black car. Anyways, i think i have seen silver loom also that will work against the silver. You going to want to blend things into the backround and/or eliminate them from the area by rerouting like i said before.
Again, take your time, and solder and heat shrink the wires when extending or shortning---do not use the stupid butt connectors, your just asking for electrical troubles using them, especially under the hood exposed to weather.
Old 06-29-2009, 10:12 AM   #31
babyJay
Arrived on a Pale Horse
babyJay's Avatar
thanks,what kind of wires are those?My wires dont reach that far,,
They are GM Performance, also from Jegs. They are available in Black as well.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Thread Tools
Display Modes
