Old 08-19-2009, 10:53 PM   #26
MickMc
MickMc's Avatar
Re: Gear Vendors Question
Originally Posted by WorkinLonghorn View Post
Sounds like you need to lose that 4.10 and get a 3.07. Or a 3.54. I've got 3.73 with 31" tires and still turn 3000 at 72MPH.
How much is a used GV? I wonder if any ever slip by the guys at Pick-your part and make it into the yard.
That's how I found my Gear Vendors.
I was crawling around a four door taking out the Tilt fourspeed (super rare) and the Hydra boost and I noticed a two-speed button on the floor shifter (an eaton two-speed button) and I crawled under that nasty truck and there was a heavy duty Gear Vendors (it has the transmission pan style). I must have spent three hours on that truck and left with a wheel barrow full of parts. When I got to check out the stupid chick had no idea what it was, but I was not going argue. She wanted to charge me a core for the "transmission" I gave up and paid the bill plus the 'core'. I smiled all the way home. Then I realized what am I going to put this on?
Mick
MickMc is offline   Reply With Quote
Old 08-19-2009, 11:00 PM   #27
EighthD
EighthD's Avatar
I bought a 77 4X4 Blazer that had a GV OD and a 350 HO motor. I put the 350 in my 71 swb. And am planing on installing the OD when I can afford it. I would like to put a 700r4 in it . Plus I have to get the correct adaptor from GV.
EighthD is offline   Reply With Quote
Old 08-19-2009, 11:13 PM   #28
dazza
dazza's Avatar
Longhorn Man, why would it drop?
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 08-19-2009, 11:41 PM   #29
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
If youre a rodder, the GV overdrive is awesome. Go 1st, then 2nd, then
2nd overdrive, and wave adiose to your oponent.
The units are bullet proof, and the people at Gear Vendors are great. Yea, Ive got aTKO, but Id definately do a GV if I were running an auto. (also, 4spd overdrives arent even close)
Tom Vogel is offline   Reply With Quote
Old 08-20-2009, 02:21 AM   #30
IAFF2407
IAFF2407's Avatar
I put the GV in my Burb with the caddy 500, used a one piece driveshaft with no problems. on the highway it drops my revs down 500 rpm. these are bullet proof and will always keep a $1500 resale 15 years down the road. When you order one, give GV's your tire size etc. and they will instal the right gear for your speedo to keep it accurate. If you change your tire size you can change that "color coded" gear. I bought mine from a hot rod shop down in Texas that CG pointed me to. saved me $300 bucks.(some where around there, just a matter of pulling out the receipt)
If you want something cheaper, a hint, GM used these in a lot of they're motorhomes with the T400. (pre electronics age) maybe find one in a wreckers/pull a part.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 08-20-2009, 06:41 AM   #31
gator2511
gator2511's Avatar
Talking Re: Gear Vendors Question
I'm running a GVOD in my K10. Rear end is a 3:73 and tires are 31" diameter. At 75 mph I'm turning 2200 rpms. I honestly don't know how much the gas mileage changed since then because I have added Vortec heads and a Comp Cam kit. Its a lot quieter in the cab at highway speeds and I look at it like I have a six speed th400 now instead of a 3 speed. I can go into OD at 40 mph or above so it can be used in the city also. I put mine in when I went to a TH400 instead of a TH350 and I had to have my front driveshaft lengthened and my rear shaft shortened. It already had a one piece driveshaft. I bought mine from a local driveline shop and have had superior support from GV. Its a lot of money but I'm glad I did it and would do it again in a heartbeat.
gator2511 is offline   Reply With Quote
Old 08-20-2009, 07:20 AM   #32
haysonj
haysonj's Avatar
I have one in my truck FI 350,Turbo 400,GVOD, 4:09 gears and 35 in tires. This truck tows a 4000 lb boat with ease and goes up hills at 55 with no problem. If you set the OD on auto it makes the turbo 400 act like a 4 speed.the unit at 55 will shift back to 3rd when you step on the gas to act like a passing gear or you can shift it manually to climb hills. I cruise around 2300 at 65 to 70 Probably the best addition I did to the truck.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-20-2009, 08:14 AM   #33
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
your RPMs are as low as you want them right now, any lower and you'll start lugging the motor
Old 08-20-2009, 09:16 AM   #34
pmpski_1
pmpski_1's Avatar
So, to get the best MPG, you have to know your torque curve. And then you need to keep the engine in the RPM range where it isn't too low. Is that correct?
pmpski_1 is offline   Reply With Quote
Old 08-20-2009, 09:36 PM   #35
IAFF2407
IAFF2407's Avatar
unless you put a caddy motor in it!
1972 GMC Sierra
Old 08-21-2009, 09:32 AM   #36
69GMCLonghorn
69GMCLonghorn's Avatar
Keep in mind, you don't always have to be at your peak torque RPM. Let's say your torque peaks at 2500 RPM. You're probably good to run down the highway at 1900-2000 RPM. Much below that and you may see a mileage drop b/c of what LHM said.
69GMCLonghorn is offline   Reply With Quote
Thread Tools
Display Modes
