Old 10-19-2009, 09:43 PM   #26
kev2809
low n' slo
kev2809's Avatar
Re: How low will it go with this setup?
you have a pic of the burr bit? do you think the hole saw will work?
this is what i bought, except mine is 1 1/2" with a bit on the inside
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-19-2009, 10:02 PM   #27
lolife99
67-72 parts collector,…
lolife99's Avatar
I think the frame is too tough for that hole saw to last. Plus it doesn't need to be that big.
Burr bit from Google:
http://www.google.com/search?hl=en&q...&aq=f&oq=&aqi=
Keith
Convert to disc brakes.
Old 10-19-2009, 10:40 PM   #28
kev2809
low n' slo
kev2809's Avatar
oh, ok. i seen one of those. well i guess ill tear it back down tomorrow after work and see how far i get lol
-_--_--_ _________
Old 10-20-2009, 10:09 AM   #29
ulakovic22
I used a hole saw on mine, but unless your template it perfect you will still need the burr bit to elongate the hole one way or the other. Also when you are drilling make sure you are using something like WD-40 so you don't tear your bits up. It will cut faster and help cool down those metal shavings so they don't burn you if some should get on you.
ulakovic22 is offline   Reply With Quote
Old 10-20-2009, 10:23 AM   #30
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I've used a hole saw to drill holes in metal several times, but this is not the time or place for it ( I also used a very slow RPM, a drill press, and LOTS of tap magic). Get a nice set of unibits and they should run through the frame like butter.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 10-20-2009, 12:31 PM   #31
SCOTI
SCOTI's Avatar
Ageed. Spend the money for a pro unibit up to the size you need. It will cut through 50x faster than the hole-saw.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-20-2009, 06:32 PM   #32
kev2809
low n' slo
kev2809's Avatar
well i guess im gonna return this hole saw since i havent used it. i checked around home depot and the biggest they have is up to 7/8, which is too small. i found this one on the lowes website...i think it should be big enough.
-_--_--_ _________
Old 10-20-2009, 06:45 PM   #33
SCOTI
SCOTI's Avatar
Stay away from Lowes for this kind of tool. Go to Grainger or Fastenall (etc....) for a 'pro' type of bit vs. 'handyman' special.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-20-2009, 07:00 PM   #34
smashingchuck
Yeah I'm thinking the reason you had trouble with the first unibit was because it was low quality. I have a set made by Lenox that I've never had a problem with.
78 Build Thread
4Runner Build
Old 10-20-2009, 07:21 PM   #35
kev2809
low n' slo
kev2809's Avatar
i thought irwin was a good brand? i dont think i have one of those around my area...the first one i bought was from harbor freight lol, so i know why that one broke
*edit* i just checked both of their sites and they both carry irwin brand step bits
-_--_--_ _________
Old 10-20-2009, 09:17 PM   #36
aford78
Built not bought!!!!
aford78's Avatar
Home Depot sells them in the electrical department, the brand of theirs is greenlee and they are around $50.
aford78 is offline   Reply With Quote
Old 10-20-2009, 09:37 PM   #37
fiddy9apache
fiddy9apache's Avatar
Some of Fastenals drill bits are pure crap, I would use 3 fastenal bits to one dewalt bit. That was drilling on stainless steal. Also there cut off wheels arnt that good, I would stay away from fastenals blackstone brand.
fiddy9apache is offline   Reply With Quote
Old 10-20-2009, 10:03 PM   #38
kev2809
low n' slo
kev2809's Avatar
the only ones i seen at home depot were irwin but only went up to 7/8..i only checked in where the the drills and saws and air tools were. thats where they had all the bits
-_--_--_ _________
Old 10-22-2009, 08:17 AM   #39
VA72C10
VA72C10
VA72C10's Avatar
Try the electrical department in Depot/Lowes as mentioned. You could also check a tractor supply store if they have one in your area.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-22-2009, 09:39 AM   #40
kev2809
low n' slo
kev2809's Avatar
I found it at home depot..50 bucks! I got it anyways, gonna try it out today. its the same one in the picture I posted, made by irwin
-_--_--_ _________
Thread Tools
Display Modes
