#26 |
I have car A.D.D.
Re: Mix & match drop kit..
Here are a couple shots of my flip & notch. Like I said, it was all done in about 7 hours in the garage one day. We did the front drop, an axle swap, & the rear drop. Hope this gives you some ideas about how it all ends up. It is not the prettiest flip & notch job ever, but...it was not supposed to be. It is functional, sturdy, and it is all straight. That was the goal.
In the 1st picture you can see the $15 spring perches. In the 2nd, you can see the notch made out of scrap metal from my buddies Suzuki Samurai build. In the 3rd you can see the overall setup. Oh, I should mention, that exhaust is going away soon, right now it is lower than my notch.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 08-23-2009 at 04:26 PM. Reason: exhaust |
#27 |
Nice thanks for the pics.
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
#28 |
Superbad
Looks good Driveway Dreams. That's one of the cheapest & I think the best way to flip the axle on a 73 - 87. Did you have to drill an offset center pin hole in the new spring perch to center the wheels in the wheel wells? Also if you don't mind them being there you don't have to remove the original spring perches, they don't interfere with the u-bolts.
#29 |
I have car A.D.D.
I did drill it to move it some. Really should have taken it a little further, but...oh well. The guy I bought the rear end from had at somepoint, tried to cut off and reuse the stock perches for a flip.
![]() So I had to cut off and grind down his mess to make it all right. There is a few areas that could have been cleaner, but again, I was going for function here.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 08-26-2009 at 12:39 PM. |
#30 | |
Dually Pride
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
#31 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Don't forget about the pinion angle.
Flip kits do the calculating for you. If you do it yourself,... you have to weld the new perches on with the correct pinion angle.
#32 |
I have car A.D.D.
It was not bad at all. Take some time to measure it to make sure they centered right. The pinion angle is really pretty easy on something like this. My buddy has done a bunch of crazy rock crawler setups and had this one lined up real quick with no issues. Just get a pinion angle tool to get it exact.
We put it all in and loosely bolted it together, then got it all lined up and tacked the perches in place. Then pulled it out and welded it up solid. Keep in mind that after you weld on axle tubes, change the fluid. It can boil in there and break down.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
#33 |
both have there pro's and con's. i wouldnt suggest goin that low if its your first lowered truck since the spring perches do hang extremely low.
#34 | |
Happy to be here
![]() Join Date: Mar 2000
While I am the opposite of you in that I don't care for low hanging spring pockets. Since I don't own anything that has 15" wheels it's rarely a safety issue. For those that are running 15" wheels, it should be given some consideration.
#35 |
Happy to be here
Driveway Dreams- Nice low buck approach. I like that you radiused the corners on your notch to prevent potential stress cracks that sharp corners could cause.
Did you box or gusset the back side of the notch?
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 08-27-2009 at 07:41 PM. |
#36 |
I have car A.D.D.
Boxed it all in. The thing is real solid. I should have taken progress pics all day but I had to get it all back together so my wife could have her side of the garage. Oh well. Next time...
#37 |
hey guys, thanks for all the info. i finally decided with western chassis 5/7 kit with summit sport truck shocks. they are in my budget and my buddy is going to do the rear for dirt cheap (fifty bucks or so he has his own shop). thanks to everyone here, im confident in my decision. But... I still have two questions:
1.Does anyone have anything to say about summit shocks, good or bad? 2.Does the thickness of my rotors factor in when ordering the wc kit(spindles) Oh yeah by the way, i just mounted BFG Radial T/A's on the chrome smoothies and they're lookin pretty sweet. Too bad it is still sittin pretty high, I'll fix that soon enough. thanks again everybody. |
#38 | |
![]() Join Date: Jul 2009
Good luck ![]() |
#39 |
I have car A.D.D.
As far as I know the Summit shocks will be another brands shock just re labeled(like most of their stuff). And, I think shocks are one of those things that you get what you pay for to a point. The more you spend, the better the internal structure will be. But they should be fine and last you unless you plan on beating the truck down rough roads all the time.
#40 |
So I have a question or two. What exactly is the angle that im looking for? I thought I could just weld the 15 dollar perches directly opposite of the ones already there.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
#41 |
I have car A.D.D.
You generally want your pinion angle to be around 3* or so, if I remember right. You just want to be sure that everything is as straight as possible from tranny, to driveshaft, to pinion. That will keep from having too much stress on the u joints, which will make them last longer and they will turn smoother.
#42 |
Any one running a flip kit out back ever towed a car trailer or hauled anything heavy? Seams like all the weight of the truck with the flip kit would get transferred to the 8 nuts on the U bolts.
51 Chevy 3100 Deluxe Cab(SOLD) ![]() 65 **stang 6cyl 70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD]) 72 C10 Short Bed Fleetside 73 Blazer 2WD Catalina Blue White Top(Needs Love) 73 Blazer 2WD Work in progress LT1/4L60E 83 Grand National (SOLD) 94 Blazer K1500 Silverado (SOLD) 96 Impala SS All original (NEXT IN LINE 2 B SOLD) 99 Tahoe 2DR, 2WD ![]() |
#43 |
TUKE-NoBullChit Customs owner
i just cut the front springs from a 454 dually if im not mistaken on my blazer back in the day. cut off the bump stop mounts and used some cheap traction bar bump stops and doubled up on the cheap vw dropped shocks up front, with the dually sway bar on the front and it rode fine. i tore up the first set of lower a-arms but on the second pair i welded a plate under the bushings to keep them from caving in there, and changed to the "squshy " bumstops. think i got those from fbi in the truckin books. this rode just fine for me, at a very low altitude i might add. your gonna scrape regardless if you go that low, just make sure you cant tear anythng up. my biggest problem id have to say , was getting it aligned, i had to change the a-arm studs to longer grade 8 or 10 bolts and make some spacers to bring them out a bit, but i rode fine and didnt waer out tires anymore, and didnt use drop spindles.
did my own flip in the back too. cut the mounts from the top and welded them back on bottom after i drilled the hole further back, used the factory stuff to put it back together, vw shocks again in back. had to cut down a 2-piece driveshaft too. the one piece hit the bottom brace of the body, but dont think you will have this driveshaft problem since its not a blazer. |
#44 |
I've pulled my 4000+ lb boat and a car trailer with a LWB '78 on it without any issues.
Thread Tools | |
Display Modes | |
