Old 09-15-2009, 10:52 PM   #26
ol Curt
Junior Member
ol Curt's Avatar
Re: ol Curt Suffers Setback...I think
Originally Posted by ruffrida2005 View Post
You know when I was in Iraq the first time in 03, My motor sergeant used to always tell us if we got pissed off at the truck we were working on to just walk away and go talk to another truck or if you could find a tree. You'll get it done we all have problems with our trucks but once they are done it's well worth the pain.
I have 722 trees on the campus I oversee. I'll go talk to them all tomorrow!
I measured from the top and the two spots mentioned were within a half inch of each other. I measured from the spot where the door check fastens down and found there to be a 1-1/2" difference between the two sides. I definitely have to consider some more reference points before doing any work
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 09-16-2009, 12:03 AM   #27
Captainfab
60-66 Nut
Yes you can MIG weld stainless with mild steel wire. It doesn't produce as good a quality weld as stainless wire, but of course in this situation that isn't a big issue. It sounds to me in this case that the stainless bolt has galled in the mild steel nut. It is worth a try to weld a nut onto the remaining bolt to try and remove it though.....you never know.
Originally Posted by Alan's Classic View Post
As far as welding to stainless with a mig, I don't think it will work. Please correct me if I'm wrong.
Old 09-16-2009, 06:43 AM   #28
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
that is proably the issue.
the 2 measurements should be exactly the same.
on mine one side was 1/8 shorter than the other, but both spots on that side were 50 7/8.
Old 09-16-2009, 09:31 AM   #29
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
It moved a little but not enough to make much difference. I thought I might go and adjust the other side a bit so it would close good. One of the new stainless bolts didn't feel quite right. I went to loosen it and it was snug. One more turn and it snapped it off in the A Pillar.
It won't be much longer and this thing will be sold off like many of the others on here. The only difference is this one is in pieces.
I may have to walk away for a few weeks!
Hang in there, talk to the trees, we've ALL been there. I work with stainless hardware a lot, being in the marine repair business, stainless is notorious for galling (esp. if an air tool is used). I've found that a COLBALT bit works great on stainless, high speed steel and nitride-coated are basically worthless. Center punch it, try a cobalt bit and an EZ-out. Also, FWIW, I'm trying to make it a habit to run a tap through critical threaded parts, even when using new fasteners, just to clean em up.
Larry
fleetsidelarry is offline   Reply With Quote
Old 09-16-2009, 09:35 AM   #30
ol Curt
Junior Member
ol Curt's Avatar
Originally Posted by fleetsidelarry View Post
Hang in there, talk to the trees, we've ALL been there. I work with stainless hardware a lot, being in the marine repair business, stainless is notorious for galling (esp. if an air tool is used). I've found that a COLBALT bit works great on stainless, high speed steel and nitride-coated are basically worthless. Also, FWIW, I've gotten into the habit of running a tap through critical threaded parts, even when using new fasteners, just to clean em up.
I think that may be the part that ticked me off the most. I did run a tap through all of them.
Old 09-16-2009, 09:48 AM   #31
jonzcustomshop
1961 crewcab
I had a hell of a time with the door bolts on my 61, a few were galled, and cross threaded from the factory I assume... they are a real fine thread, and it seemed whenever I started a bolt it would try to cross.
I ended up pulling bolts off of 2 different trucks before I found some that ran in and out real nice.
I also had to grind a little of the cab away around the bolt hole to get the caged nut to adjust down far enough to get the hinge to line up.
the whole process was real challenging, and I felt like giving up a # of times
Old 09-16-2009, 11:03 AM   #32
MacAttack
283 Drama Queen
MacAttack's Avatar
Outstanding! That's what this site's all about!
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 09-16-2009, 01:59 PM   #33
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I'm just happy I've been quoted on something. HAHA
hang in there Bob.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 09-16-2009, 02:15 PM   #34
1964C10
1964C10's Avatar
Hang in there Bob! and welcome to the "Broke-a-bolt" club lol. Membership is free but careful it's like Hotel California, you can check in but you can never leave hahaha
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 09-16-2009, 08:10 PM   #35
ol Curt
Junior Member
ol Curt's Avatar
Tried to weld a nut on...wouldn't hold. Tried to drill hole and use easy out...ended up knocking the whole plate out the back. After taking some of the rocker apart on that side was able to fish out the plate. Obviously, it must sit in some kind of tray and it was rusted.
I'm trying to decide whether to take it to a machine shop and just have them make a piece.....or sell all the parts and pieces!
If I have the part made, then I have to figure how to fish it back up into place and get it to stay put....oh brother!
Old 09-16-2009, 08:20 PM   #36
ruffrida2005
If you have to you can always cut the peice off the piller and weld a nut. then weld the peice back on.
Paul
Old 09-17-2009, 07:35 AM   #37
ol Curt
Junior Member
ol Curt's Avatar
That.....Is a DEAL! I suddenly feel a little rejuvenated. There are no bone yards around here.
I bought a big ol bottle of anti seize yesterday, and a big ol bottle of advil! I am not sure t wasn't just a bit cross threaded. All five other bolts turned like they were in butter.It had only been in ther efor a day.Either way, I don't thinkI will be using them for the fine thread parts.
Old 09-17-2009, 08:16 AM   #38
jason65
Registerd User
jason65's Avatar
Nice hook up.
jason65 is offline   Reply With Quote
Old 09-17-2009, 10:30 AM   #39
MacAttack
283 Drama Queen
MacAttack's Avatar
Originally Posted by MailManX2 View Post
It'll take me a couple of days to get it cut out and boxed up. Let me know..
It doesn't get any better than that!
Old 09-17-2009, 10:49 AM   #40
ol Curt
Junior Member
ol Curt's Avatar
Originally Posted by jason65 View Post
Nice hook up.
You got that right...especially after I snapped an easy out off in the bolt this morning!
Old 09-17-2009, 04:29 PM   #41
ruffrida2005
yeah that probably isn't that good Bob.
Paul
Old 09-21-2009, 08:40 PM   #42
ol Curt
Junior Member
ol Curt's Avatar
Originally Posted by jonzcustomshop View Post
from these marks you should have 51 inches in both spots.
I noticed that the measurement was about 1/8th of an inch off on the passenger side of my 61 (50 7/8), after much inspecting and remeasuring , the measurement was off by the same amount in both spots on that side, I acertained that the rocker was welded on a little crooked from the factory
Ok, I took the door off tonight...I'm starting to feel like a power lifter again!
I want to make sure I have this absolutely right. From the BOTTOM edge of the drip rail to the edge of the rocker where the door meets it is 51" front and back. Correct? It appears I am at 50-5/8" on the back and 51-1/2" on the front.
Roughly a 1/2" shift front and back. That would seem to make a big difference.
Old 09-21-2009, 09:48 PM   #43
ruffrida2005
Measure a million times, Weld once. haha Hang in there. Atleast you get to work on your truck. Mines 4 hours away.
Paul
Old 09-22-2009, 06:47 AM   #44
ol Curt
Junior Member
ol Curt's Avatar
Yeah, I just want to double check the height before I start the grinding and begin resetting.
Old 09-24-2009, 01:42 PM   #45
Roadhammer
Roadhammer's Avatar
I like a week away from starting on my "repop" rocker installs from LMC and im scared to death by this thread..I think ill go out and buy a sixpack of measuring tapes that might make me feel bteer. LOL
Jory
Roadhammer is offline   Reply With Quote
Old 09-24-2009, 03:18 PM   #46
ol Curt
Junior Member
ol Curt's Avatar
Mine are good to go now...at least i think. Will be putting door on this week. One of the things I didn't do, because I thought it would limit my working room is to brace the cab first. I also rented a video set and that guy didn't brace. Alan has some good info in his threads for this work(he definitely braced). I don't know if I have ever seen anybody as good as him on body work. I would follow everything he did!
Old 09-24-2009, 08:58 PM   #47
ol Curt
Junior Member
ol Curt's Avatar
Hey,
Wanted to let everyone know Mailman hooked me up with part of a pillar so I can fix my drivers door hinge pillar. Not only did he cut it out and send it, he blasted it....heck, ol curt kinda shivered when I was holding a blasted piece up to him. He hadn't ever seen one of those before!!
I was busy working on getting it all lined up before cutting it out tonight and didn't take any pics, but will tomorrow.
Thanks again Ken!!
Thread Tools
Display Modes
