Old 11-19-2009, 08:31 PM   #26
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: New Seats installed
Ttt
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 11-19-2009, 10:26 PM   #27
lsx72
Originally Posted by 71meangreenc10 View Post
Ttt
smitty, them look great. i have not decided which seat i want to go with yet. im thinking about the 88-95 bench seat with the little arm rest that folds down. reason being is i know a guy that has one in his 72 and he said it is great.. smiddy how do they sit? are you real high up like with the back breaker? ....robbie
lsx72 is offline   Reply With Quote
Old 11-19-2009, 10:40 PM   #28
Beuford
Beuford's Avatar
I put `97 chevy truck seat in mine with electric air adj lumbar. simple install because the seat belts from the `97 bolted to the floor. I used the shoulder harness also since the cab was drilled for them.I put the gas tank under the bed.
Beuford is offline   Reply With Quote
Old 11-19-2009, 11:47 PM   #29
lsx72
looks good. how do they sit?
Old 11-20-2009, 03:27 AM   #30
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
I really like the idea as well im just still having trouble with deciding what year seats to work with i just know i want the fold down 3rd seat and a real easy install lol
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[COMPLETE-EDELBROCK]
[PERFORMANCE-SERIES]
[CAM_CARB_MANIFOLD]
...TURBO-400_TRANNY...
CUSTOM_1O is offline   Reply With Quote
Old 11-20-2009, 04:42 AM   #31
mikey531
mikey531's Avatar
Go with 99 GMC/Chevy and up for quick and easy. Seats belts integrated and just drill the holes for the bolts. It took me about an hour to install mine. You will need some help tightening the center bolts. Hook up the power and then ride ! Post any questions and I will try to answer.
mikey531 is offline   Reply With Quote
Old 11-20-2009, 05:24 AM   #32
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
nice and thanks alot???
you wouldnt happened to have any pics of you doing the whole process would you ??? and what wholes would need to be drilled i thought everything was pretty much bolt or is that just for the front bolts... and i know nothing about electrical sound i would really need some help with that..
thanks for your time
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[CAM_CARB_MANIFOLD]
Old 11-20-2009, 05:31 AM   #33
mikey531
mikey531's Avatar
None of the holes lined up but they are 3 separate pieces and sit in perfect. All I did was put in the center section first and got it where I wanted it. The inside seat bolts bolt through the same holes as the center section so it was real easy to do. I was going to take pictures but it went so fast I kind of forgot.
Old 11-20-2009, 07:38 AM   #34
Beuford
Beuford's Avatar
They ride nice. I'm 6`3" and we've taken 2 trips of 400+ miles one way and no cramping. They do sit about an 1" higher than the stock seat. But for my long legs that was a plus and they don't cut into the back of my wifes legs as she's 5'6".
Old 11-21-2009, 08:21 AM   #35
71meangreenc10
Robbie,
They sit great, they feel like they belong in the truck, just a tad higher than the bench I can measure if you like. I also like the look of Beufords 97, my thoughts are I wanted something that looks like it belongs in the cab, thats why I went with mine, i didnt drill any holes in my cab, dont want to. I want it to look clean. Some of the seats just dont look right, slide rails sticking out ect, but use what you can to best fit your needs. I can tell you that with 4, 6 inch pieces of 1/8 angle and a 5/16 drill bit with 12 grade eight bolts, washers, and a little patience, you can have a nice seat set up. (And a donor Dodge will help too )
Mine also has the adj lumbar.
Smitty
71 C30 Wrecker
Old 11-21-2009, 08:54 AM   #36
ripdog28
ripdog28's Avatar
Not to cheap but reasonable, I will be going with this company. Still deciding which ones. They also have brackets for our trucks.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 11-21-2009, 09:11 AM   #37
71meangreenc10
Have you called them about the brackets? Cant seam to find them on the site. Are they direct bolt in or drilled?
Smitty
71 C30 Wrecker
Old 11-21-2009, 10:44 AM   #38
ripdog28
ripdog28's Avatar
If you click the seats you want, at the bottom of the page they have all the brackets. It is a direct bolt it. I Think under 50 bucks. You can get electric, lumbar, heat.....
69 c-10 BBC
Old 12-03-2009, 11:31 AM   #39
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Great ideas and seats guys!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 12-03-2009, 12:45 PM   #40
Rokcrln
Rokcrln's Avatar
When I do the newer seats with integrated belts I weld 2" x 1/8" plates to the floor and weld nuts to those as well to make install a one-man job.
Here is what the bottom of Lemon Drop looks like.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-16-2010, 02:09 PM   #41
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Ttt
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-16-2010, 07:24 PM   #42
Mxracer202
Mxracer202's Avatar
Good thing I saw this thread first was just about to make a thread about seats, but you answered all my questions.
I am looking to get a bench seat with a center console for my 67, but dont need all the electric stuff, cause it will be a off road truck
If you dont mind, how much did you guys pay for your seats?
58 Jeep willys pickup
67 K10 4x4- soon to be trail truck
TROUBLE MAKER RACING
"If you can't stand BEHIND our troops, please stand in FRONT of them."
Mxracer202 is offline   Reply With Quote
Old 01-16-2010, 07:36 PM   #43
mikey531
mikey531's Avatar
I found mine on Craigslist for $250. They are leather and power.
Old 01-17-2010, 10:45 PM   #44
Tbobbo
Originally Posted by mikey531 View Post
I got my new seats in this weekend I found them on CL. They came out of a 99 GMC so I now have the shoulder belts. I got the power hooked up and they work great ! I had some thick fabric that I got somewhere, ( can't remember) I was going to use it for a headliner in my '74 but never got to it. It matches pretty good so I used it to cover the tank and I have enough to do my door panels too.
Wow nice job man! Looks great and looks comfy
Tbobbo is offline   Reply With Quote
Old 04-04-2010, 01:23 PM   #45
67/72junkie
Nothing fancy but very comfortable and cheap.$15 at the scrap yard.Out of 90 something chevy pickup.front 2 bolts went in factory holes.had to drill 1. hole on each side for the rear.Used 1/2'' thick x 1" wide wooden shim to make seat sit level temporary until I can pickup a couple small aluminum blocks.Sit a little higher than factory bench.Name:  101_0162.jpg
67/72junkie is offline   Reply With Quote
Old 01-10-2011, 10:21 AM   #46
legendary
legendary's Avatar
Did any of you use this site as mentioned earlier?
http://www.discountvantruck.com
Best Regards,
Leon
1970 C/10 LWB Cummins Turbo - Build in Progress
Many other toys as well...
legendary is offline   Reply With Quote
Thread Tools
Display Modes
