12-13-2009, 04:07 PM | #26 |
Re: Truck arm rear suspension
What are the options for exhaust with the truck arms ? My mufflers are just ahead of the rear axle, seems they would be in the way of the arms ? Never seen the exhaust on a stock 67-72 but imagine the mufflers have to be ahead of the trailing arm crossmember ?
1977 GMC Sierra Grande Last edited by Pyrotechnic; 12-13-2009 at 04:08 PM. |
12-13-2009, 05:06 PM | #27 | |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
12-14-2009, 12:17 PM | #28 | |
Still plays with trucks
I did see one who routed the tail pipes under the rear axle. Don't know how well that worked though.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
12-14-2009, 12:24 PM | #29 |
The rubber bushings allow more articulation than you would believe. A ladder bar system would articulate if it didn't have a diagonal link bar tying one front mount point to the rear of the other side. With a panhard bar like the truck arm it would articulate pretty well.
With the Cal-Trac pivot bolt snug against the spring and preloaded like it needs to be to work well there is literally enough pressure on the spring that you can lift the whole back end of the car by putting a jack under one shock plate.
Thread Tools | |
Display Modes | |
