Old 01-20-2010, 03:55 PM   #26
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Finally!!! 67 C10
Man what a find, and it sounds like you have a pretty good list of future upgrades.
One thing I will tell you is this... it is only original once. The original paint... only original once.
There are several guy's (including myself) that would kill to locate an original paint (patina'd) SWB like that. Nothing looks better than an original truck lowered with a nice set of wheels.
Any other rust issues? How's the inside of the bed since it had a camper on it?
Again, congrats on the truck, and I hope that I didn't come across like I didn't like your plans. Be sure to start a build thread when you start working on it.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-20-2010, 05:08 PM   #27
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
The bottom of the door/rocker was the only rust I found. I took some long needle nose pliers to pull all the pine needles/leaves out of the cowl, and everything down in there *looked* fine. The bed is in good shape, the camper top has been on it as long as I can remember. Although, as with any build, I'm sure I'll find the rust when I start tearing into it.
Also, after I got home from hauling it, as soon as I stepped out of my truck, there was a strong smell of gas. I opened the door of the truck and the floor boards were wet with gas, so there is a leak in the behind the seat tank somewhere. I leaned the seat forward, and by looking at the tank I assume it has been replaced sometime. The gas line looked fine, and the fitting did not look to be the source of the leak, and neither did the filler neck. Seams on the sides looked fine, so I can only assume the leak is coming from the rear of the tank somewhere. I plan on switching to an under the bed tank anyway, so I guess I will just do it a little sooner than planned if the leak is not an easy fix. (Another reason, why I have not attempted to start it yet, I will probably just put a short piece of hose to a gas jug to see if I can get it running).
And I understand you completely about the patina. First priority is getting it running, then I will start going through it, upgrading it as I get to it. I will probably run the patina look for a few years. Right now I am trying to track down the missing trim from the drivers rear fender, as well as maybe a new piece for the passenger front fender. Looking for used pieces though, so it all matches somewhat and keeps the "patina" look. After fixing a few pieces, and patching that rust, I will probably go ahead with the drop, and probably run some Corvette style rallys, 15x8 in the front and 15x10 in the rear with some meaty tires.
Guess I'm a little partial to that look though:
Then, since I plan on upgrading to power steering and power disk brakes, I will probably hold off on that till I decide to swap in a LS series motor and a 5/6 speed, and do it at the same time, probably with a hydraboost brake setup.
Then after I've got it about where I want it drive train-wise, I will tear it back down and paint it how I want it, and then probably go to some nice chrome wheels.
If it was an original big block truck, or something of that sort I might would consider restoring it to original, but since it was a bare bones 6cyl truck I don't feel too bad about changing it up. Besides, I will NEVER sell it, so value means nothing to me, and I have always loved 67-68 C10s, and always envisioned how I would set one up to be just what I want. But like I said I am a poor college student, searching for a job after I graduate this spring, and I am getting married in the fall, so this will be a long, slow project, and the patina look will stick around for a few years.
Also, I found this picture. I'm on the right, and the original owner is on the left. This was taken in 95, so I was 8 at the time, and he was 83. I'd also like to get this picture retouched/restored, to keep in the truck, as reminder of it's history. So if anyone knows of a good place to do that, for not too much $$ let me know.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 01-20-2010, 07:35 PM   #28
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
that sure is a nice 67 , don't worry about the six banger running IT WILL !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 01-20-2010, 07:46 PM   #29
gcburdic
Restoration Virgin!
gcburdic's Avatar
The more I look at your truck, it reminds me of this one....it's owned by an elder gentleman that visits the landfill I work at.....It is bone stock....the only item on the SPID is vinyl seat
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-20-2010, 09:49 PM   #30
72BlckButy
Tot Roddin'
72BlckButy's Avatar
You have some great plans for the truck, and the story behind it is about as good as it gets. I wish you the best and you might even be surprised with that little 6 banger, but then again I'm partial.
Beautiful truck and best of luck with it in the future. I know the previous owner will be proud the thing is still being loved as he did from the day purchased it.
Congratulations on graduation as well as the upcoming marriage!
-Nate
Old 01-20-2010, 09:58 PM   #31
GCncsuHD
GCncsuHD's Avatar
Minus being a 68 vs my 67, stepside, mine still having paint on most of the hood and all, yea I guess I see the resemblence.
And base model, and vinyl seat are the only two codes on the SPID of this truck as well. Also that one you pictured has another option mine doesn't: Passenger side mirror. (My 70 Chevelle only had drivers side mirror as well.)
Thanks!
ΜΟΛΩΝ ΛΑΒΕ
Old 01-20-2010, 10:17 PM   #32
JRBECK64
I love these stories. I wish I could have got my Grampas truck and believe it or not he actually died in it. He put 13 cinder blocks in the back of his truck because it was Icy and was heading to the house and he had a massive heart attack and died. Grandma found him slumped over with his foot still on the clutch and the engine running. It was a 66 Long Fleet with all the bells an wistles but my Cousin beat me to it because he lived near my Grandparents. Not long after he got it he wrapped it around a telephone pole and that was the end of that truck (Cousin had a few bruises). Glad to see you got your Grandpa's truck.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 01-20-2010, 10:22 PM   #33
ChiefThinElk
ChiefThinElk's Avatar
I agree with 72BlkBeauty, my old neighbor has one exactly like it, original owner, he wants $2500 for it, I been saving to take it off his hands but something always comes up. There's always the risk someone else will buy it but no one has in the last 20 years but you never know.
ChiefThinElk is offline   Reply With Quote
Old 01-20-2010, 10:26 PM   #34
72BlckButy
Tot Roddin'
72BlckButy's Avatar
And where do you live ChiefThinElk??? Always looking for the next project....
-Nate
Old 01-20-2010, 10:31 PM   #35
ChiefThinElk
Everytime I drive by it I think, there's my truck, the old coot just waves at me. Congrats on the truck!
Old 01-21-2010, 12:14 AM   #36
gcburdic
Restoration Virgin!
gcburdic's Avatar
I think it's your story about your great grandpa that reminds me most....check out this thread where some awesome members pitched in and hooked him up with a hub cap that was missing....http://67-72chevytrucks.com/vboard/s...d.php?t=364298
BTW....you must be very excited about NCSU clobbering Duke tonight!!!...Good Game!!!
Geoff with a G
Old 01-21-2010, 01:39 AM   #37
GCncsuHD
GCncsuHD's Avatar
Haha yep! I just watched it. Even better that UNC lost the same night. I know my ABC's well Anybody But Carolina & Duke.
Great story about the hub cap as well.
ΜΟΛΩΝ ΛΑΒΕ
Old 01-21-2010, 02:29 AM   #38
love my 72
love my 72's Avatar
Some body photo shop his truck with a 5/7 drop and some 18x10" and 18x8" rally wheels on that awesome patina the truck has going, at most i would add a gaylords tonneau cover matching the paint!
but then again its not my dream trck
51 Chevy 3100 Deluxe Cab(SOLD)
65 **stang 6cyl
70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD])
72 C10 Short Bed Fleetside
73 Blazer 2WD Catalina Blue White Top(Needs Love)
73 Blazer 2WD Work in progress LT1/4L60E
83 Grand National (SOLD)
94 Blazer K1500 Silverado (SOLD)
96 Impala SS All original (NEXT IN LINE 2 B SOLD)
99 Tahoe 2DR, 2WD
love my 72 is offline   Reply With Quote
Old 05-26-2013, 11:04 AM   #39
Hart_Rod
Hart_Rod's Avatar
Updates?
Hart_Rod is offline   Reply With Quote
Old 05-26-2013, 11:20 AM   #40
fastnotch89
fastnotch89's Avatar
Killing looking truck, youre not far from me
fastnotch89 is offline   Reply With Quote
Old 05-28-2013, 08:07 AM   #41
GCncsuHD
GCncsuHD's Avatar
Originally Posted by Hart_Rod View Post
Updates?
No real updates, it is torn down to the bare frame currently, we've been building a house, so once I get the 3 car garage finished I have a bay just for this truck so I'll have no more excuses and I'll get to work!
Thanks!
ΜΟΛΩΝ ΛΑΒΕ
Old 05-28-2013, 09:55 AM   #42
67anthony
Man great truck
67anthony is offline   Reply With Quote
Old 05-28-2013, 11:26 AM   #43
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Nice truck and a great story to go with it. I know how you feel i got my dads truck.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 05-20-2014, 11:52 AM   #44
Hart_Rod
Hart_Rod's Avatar
bump
Old 05-20-2014, 12:04 PM   #45
luckyss
Awesome
luckyss is offline   Reply With Quote
Old 05-20-2014, 02:45 PM   #46
GCncsuHD
GCncsuHD's Avatar
bump
Well...since the last time you bumped this, oh about this time last year, we had just found out we were going to be having a kid, she's 7 months now and getting big, needless to say, the garage isn't finished, and the truck is still in storage at my parents house... Now we just found out we have another on the way soo...I might get this done when I retire in 50 years...
Keep bumping it to give me the kick in the rear I need
But.... Since we all like pictures, and it does need an update even if it's not all truck related.
The frame is currently sitting inside my parents shop, bare, waiting to be taken to the blaster, but currently doing a fine job as a table/dog bed.
IMG_20130223_112556_608 by wrfalcon75, on Flickr
I did acquire a low mileage 5.3, a flywheel and clutch to adapt it to the existing 3 speed (yea, I'm a little nostalgic), fuel system is all worked out, and I have already thinned a harness.
I have acquired probably 90% of the parts I need to put it together, including front power disc brakes, suspension, exhaust, interior stuff, etc. I just need to find the time to get to work on it.
I did help my father in law pick up a 69 K5 to work on,
Though it was in pretty bad shape and has had some setbacks
Annnd the reasons why I haven't been getting any work done?
Here is the house, about this time last year, a couple months before we moved in
30 by wrfalcon75, on Flickr
And the garage, aka future home of the 67, 30x36
34 by wrfalcon75, on Flickr
40 by wrfalcon75, on Flickr
The red dually is currently taking up residence in the 67's bay until I clear out a bay in the barn for it, and move the 67 in to work on.
Untitled by wrfalcon75, on Flickr
It's a bit of a squeeze...(9' door...the dually is 105" wide at the tires...)
But once inside there is decent room to work, especially considering the 67 will be a few feet narrower overall...
Gotta have a place to work right?
And tools to do the work
Now the project is to clean up the rest of the move in boxes etc. from the garage, and finish up some honey-do's for the wife so I can actually do some work in here.
AND the biggest reason I get nothing done...
(notice, not even a day old here, and already practicing the wolfpack hand symbol, she's about got it with her right hand!)
IMG_78768488466838 by wrfalcon75, on Flickr
Duhnduhnduhnn.... (dramatic music) the sequel is coming!
IMG95201405059518433795558 by wrfalcon75, on Flickr
ΜΟΛΩΝ ΛΑΒΕ
Old 05-20-2014, 03:21 PM   #47
CGerow
CGerow's Avatar
All good reasons to have the Chevy on the back burner! What a beautiful baby! Awesome truck and a gorgeous new garage....is there a house attached to that sweet garage? LOL!
My question, totally unrelated to the truck is, What color and brand of siding did you put on your house? We are residing and that looks similar to what we are planning but have yet to find a suitable pic ....
Cam
CGerow is offline   Reply With Quote
Old 05-20-2014, 03:30 PM   #48
GCncsuHD
GCncsuHD's Avatar
Cam
I don't recall off the top of my head, but I did keep some scraps under the house for future reference/repairs, and made sure to have some scraps with information stickers on the back so I'll try to remember to look.
ΜΟΛΩΝ ΛΑΒΕ
Old 05-20-2014, 03:53 PM   #49
LSUMurse
LSUMurse's Avatar
This picture has been my desktop background for about a year now. Thanks.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 05-20-2014, 09:28 PM   #50
jlaird
jlaird's Avatar
What a nice truck to start with, and kept in the family to boot.
jlaird is offline   Reply With Quote
Thread Tools
Display Modes
