#26 | |
Re: How much HP do I need for easy passing at 60mph?
http://community.webshots.com/user/hotrodhorn |
#27 | |
Solid. Reliable. Power to spare. This combo has been pushing these trucks around for 40yrs w/o issue....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-22-2010 at 08:05 PM. |
#28 |
Member of the longbed union.
You sound swap in a cummings Loads of the fun stuff you need to pass. Also swap the injectors and put a six shooter, and propane injection. Then you'll be moving in no time.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#29 |
BB motor= lots of torque + good passig/pulling capabilities.It's that easy.No matter what gears you have.
#30 |
Well I cannot talk in GM-speak since my stuff is weak, but my Dodge 2500 LB QC HEMI w/345 Hp can get up and go at 60mph and pass all day. I carry about 1500 lbs of tools and etc in it all the time. It has 3.73:1 gears.
For a gasser you will need to get some revs out of the engine for real bursts of power, so lower gears are a must.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
#31 |
The answer to your original question has been addressed...But, if you wanted to just haul the bike you could go a different route depending on how low your Subaru is. You could just get a utility trailer and haul the bike with your Subaru. That's what I ended up doing with my Forrester. The bike is light enough that the 4 banger has enough oomph, and I'm getting 27 mpg with the trailer. I don't think I can get that with my 350\350 with 4.10s. And the bike is much easier to load on the trailer after a long day riding.
Curry in a Hurry: SB rebuild for my 71 C20 |
#32 |
I have ~280HP and ~330 ft/lbs of TQ in my 4,000 Bonneville, and it passes people just fine, and gets 30 mpg on the freeway.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
Thread Tools | |
Display Modes | |
