Old 01-26-2010, 05:04 PM   #26
crakarjax
crakarjax's Avatar
Re: security question
Originally Posted by big_al_71 View Post
I have a kill switch that it is so simple that even when I showed some of my guys they still could not figure it out where it was at.......
I know where it's at. You took the shift lever off of your unused column shift, and slide it into 1st when its parked. Can't start the car unless it's in park, right?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-26-2010, 05:15 PM   #27
airdale94
airdale94's Avatar
These have been talked about on here before, but they are good ones. I have used the starter kill on a Firebird I had.
http://www.bfranker.badz28.com/fbody/starterkill.htm
http://autospeed.com/A_107975/cms/article.html
airdale94 is offline   Reply With Quote
Old 01-26-2010, 05:31 PM   #28
k2rm
k2rm's Avatar
I have a cable hood lock that uses a key inside the cab. I bought if from JC whitney over 15 years ago, they don't sell them anymore.
There is a strong flexible tube that keeps the cable safe between the lock and the firewall. A thief would have to cut it using a saw or bolt cutters up and under the dash to get to it, but it will take a lot more time. Inside the engine bay, the hood lock has a switch, that I wired to a relay to interupt the HEI. They would have to break into the engine bay to bypass the relay.
Probably before they would try to break into the engine bay, they would try to hotwire the truck from inside the cab, but all it would do is crank and crank and eventually flood the engine. The starter noise alone would act as a good alarm
Even with this though, I am strongly thinking of having a Lojack installed. Too much time, money, and history in my truck to risk.
k2rm is offline   Reply With Quote
Old 01-26-2010, 05:56 PM   #29
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Isn't the purple wire just a momentary contact in the ignition switch to the starter? I really don't know. I'm asking because; if you put a momentary push button in series with the purple wire to push when starting the truck won't that make it a bit tricker to start? Or even a momentary switch with a toggle switch to start. I'm thinking make it as tricky as possible to start it, but still keeping it relativity simple for you to start it. In my '51 I'm using a hidden proximity switch to drive a relay to start the truck, and a toggle switch to turn on the accessories; such as the fuel pump and other such things that need to be on with the truck. So unless the thief knows what a prox is and looks like they will have no idea what to do.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 01-26-2010, 06:50 PM   #30
coloradosean2009
coloradosean2009's Avatar
Originally Posted by bigguy69 View Post
no nothing was gone,but i came in kind of late last night. i think all this rain kept them from being out ther to long. it justs makes me mad. you will have to make more room in your garage!
You know they will be back. I would be ready with my H&K USP and a box of ammo. Just make sure you don't get any of the tweaker blood on you. That crap is toxic.
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 01-26-2010, 09:32 PM   #31
airdale94
airdale94's Avatar
edit
Old 01-26-2010, 09:56 PM   #32
gkesseru
gkesseru's Avatar
I once saw a key operated valve that you put into the brake system. You step on the brake, turn the valve with a key and the brakes are locked until you use the key to release the brakes. To make it even harder, the key was circular no-tamper type. A similar valve cutting the fuel would also be good. Anyone heard of this?
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 01-27-2010, 02:31 PM   #33
6D8_C10
6D8_C10's Avatar
I have heard of it. But it was many years ago. 20 maybe? Not sure where. I think it was Car Craft or Hot Rod Mag.
68 c10 350/th350 winter daily driver
90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver
"Just so we are reminded of those who are held back,
Up front there ought to be a Man in Black". Johnny Cash.
6D8_C10 is offline   Reply With Quote
Old 01-27-2010, 05:19 PM   #34
CCCC
CCCC's Avatar
Our trucks are so easy to hot wire that the shut-offs, relays and other smart moves can turn out to be more trouble for the owner than the potential thief. Some alarm/kill systems can be very good protection ($$$) and there always is Lojak ($$$). Our home location is about a zero threat for theft, but here are some things done with the trucks that go out into the cruel world.
Coated chain/lock for hood (stored inside hood for use when the truck will be sitting exposed for any time under risky conditions) - plus - easier disconnect battery ground cable (remove and stow in plastic baggie in Kleenex box under seat) - plus - hidden kill switch for electric fuel pump (any thief that gets past the first two will only go a short distance). Some may laugh, but in some conditions and for discouragement of the less persistent thieves, I also use a high quality (truck sized) "CLUB" on the steering wheel. Not at all sophisticated - but inexpensive, and have not lost any trucks yet.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Thread Tools
Display Modes
