02-16-2010, 11:19 AM | #26 |
Re: how much is this worth
your research is wrong. That is a buick engine. Cant tell what size from the front as all buick engines look very similar from that angle. Chev, olds, and pontiac have the distributor in the back. Buick, cadilac and fords have the distributor in the front. As far as the value of the truck, I would put it at whatever the box is worth. Anyone that would drop a buick engine between the framerails, and walk away from the project, has probably hacked the rest of the truck as well.
02-16-2010, 11:46 AM | #27 | |
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 02-16-2010 at 11:51 AM. |
02-16-2010, 01:26 PM | #28 |
Ill have to tell the guy this
02-16-2010, 03:26 PM | #29 |
I couldn't tell you what it was
02-16-2010, 03:36 PM | #30 |
If this is the case, run away from this one as fast as you can. If you can hold out, you should be able to find one around $1,000 that you could at least drive around while you fix it up. If you sunk $1,000 into this jewel it still wouldn't be able to see the road. It's worth $400 , but it sounds like you need some wheels ,and if this is the case, I do not think its a good deal. This one is not worth the gas to go look at it. JMO
Working on my first 1,000 post. I'm sure I'll get there before this project is over . |
02-16-2010, 04:52 PM | #31 |
i see what yall are sayn its just hard to find them close to tn or in tn for my price range being a swb
02-16-2010, 07:34 PM | #32 |
Thread Tools | |
Display Modes | |
