Old 05-23-2014, 08:00 AM   #26
K98AL
K98AL's Avatar
Re: Simple Headlight Upgrades
I'm going to add the relay harness this weekend - been looking at replacement bulbs that take the H4 bulbs, any recommendations? I'm running a '60 grill, so I've got four 5.75" headlights.
K98AL is offline   Reply With Quote
Old 05-23-2014, 08:33 AM   #27
theastronaut
theastronaut's Avatar
Cibie or Hella are the best lights available. I just put a pair of Cibie's in my '87 Conquest and they're definitely worth paying extra over the cost of Hella lights. We have Hella's in our S10 and they're good too. Don't go with the cheap eBay lights; the light pattern isn't nearly as good and they put off more glare. I would do two H4's and two H1 high beam bulbs.
Daniel Stern has Cibie's here:
http://www.danielsternlighting.com/p.../products.html
Hella's from rallylights.com
http://www.rallylights.com/all/light...eter_width=765
theastronaut is offline   Reply With Quote
Old 05-23-2014, 09:17 AM   #28
markeb01
Senior Enthusiast
markeb01's Avatar
I used Hella H5006A low beam bulbs on my 1960 GMC with 4 headlights. I bought them through Amazon. The installation can be seen on post #855 (page 35) of my build thread.
http://67-72chevytrucks.com/vboard/s...444502&page=35
I don't use the high beams enough to justify the expense of an upgrade, so I'm still running halogen sealed beams on the high beam circuit.
The Hella lights are super easy to align as the cutoff is so clear and sharp on a garage door, and the light output is incredible compared to sealed beams.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-23-2014, 09:46 AM   #29
K98AL
K98AL's Avatar
Ordered the Hellas. Thanks for the info - I can hardly wait to see the difference.
Old 05-23-2014, 05:12 PM   #30
Pappyx3!
Pappyx3!'s Avatar
Markeb01,
Thanks for the detailed info, I plan to do this on my 62 when I have a chance. I spent hours in your build page this week. Thanks for all the effort to document the progress. It's like reading a biography on you and the truck.
Great Work!
Pappyx3!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline   Reply With Quote
Old 05-23-2014, 05:58 PM   #31
Ronw435
Ronw435's Avatar
Great idea, thanks for the post.
Ronw435 is offline   Reply With Quote
Old 10-03-2014, 10:14 AM   #32
LuckyLightning
LuckyLightning's Avatar
Hey Markeb01 and TX Firefighter: what "path" did you guys use to run the relay wires? On my '62, there's not a whole lot of room to slide the connectors through to the headlights. I'm concerned I may have to do more dismantling than I planned. I'm just wondering what you guys did that worked for you? I'm thinking I'm overlooking an easy solution, and have the hopes I don't have to do more than is necessary.
Michael
- 1962 C20 LB stepside (project thread) - sold
- 1963 Chevy C10 LB stepside (donor)
- 1963 Chevy C10 LB Custom flatbed (project thread) - sold
- 1979 K20 LB fleetside (project thread)
Favorite exchange on the board so far:
ol_Curt: "Jason, do you have power steering?"
jason65: "No, but I lift weights."
LuckyLightning is offline   Reply With Quote
Old 10-03-2014, 12:18 PM   #33
Garagisti
Garagisti's Avatar
I did this and added HIDs. No dip in the voltage, just nice bright headlights. Lights up the road better than my Mercedes.
1965 Chevrolet C10
2016 Mercedes S550
1992 Mercedes 300TE
Garagisti is offline   Reply With Quote
Old 10-03-2014, 04:14 PM   #34
LuckyLightning
Nevermind, I got it done. What a pain though.
Michael
Old 12-24-2014, 11:16 PM   #35
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by markeb01 View Post
...clip...
The second improvement is a jumper harness that redirects the source of low beam power from the dimmer switch to the headlight switch. Under high beam conditions, the normal low beam filament goes out, and a dim filament in the bulb illuminates along with the high beam lamps. The jumper keeps the normal low beam filament illuminated anytime the headlight switch is on, regardless of the dimmer switch setting.
You can buy this jumper from Ron Francis Wiring for about $15.00:
http://www.ronfrancis.com/prodinfo.asp?number=BJ%2D2
Or - if you have the spare parts available in your electrical stash, a free version can be assembled using the following diagram:
As far as I can tell, this is just simply splicing the dim lead to the power in from headlight switch.
So when you pull the headlight switch it powers the low beams without going through the dimmer.
All the dimmer switch does is switch the high beams. Low beams stay on controlled by headlight switch.
66 C20 Service Truck:
Thread Tools
Display Modes
