Old 03-07-2010, 11:51 PM   #26
54Caddy
GM Addicted
54Caddy's Avatar
Re: New Parts, New PROBLEMS!!!
damn this is weird. so it misses once you put it in gear or when you take off? is the fuel old? i had a 74 nova that had some weird problems until i drained the tank with the old fuel. also it could be missing from fuel starvation. fix your idle and get your carb adjusted good then check your fuel filter maybe its clogged up of the filter in the carb could be depending on what style carb you have. this is a weird one
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 03-07-2010, 11:58 PM   #27
bitchin85
bitchin85's Avatar
yeah itsreal weird.. and it misses while im driving it, when i rev it in park it sounds fine...and i know the gas isnt bad i put a brand new tank init about a month ago and i just filed it up the other day. my fuel filter is only a month old too..
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 03-08-2010, 12:00 AM   #28
54Caddy
GM Addicted
54Caddy's Avatar
what about your carb what style is it do you have it tuned right.
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 12:02 AM   #29
bitchin85
bitchin85's Avatar
itsa newer edelbrock 1406 600 cfm. the tuning, other then the idle mix, is how it came right out of the box
Old 03-08-2010, 12:08 AM   #30
54Caddy
GM Addicted
54Caddy's Avatar
how did you do the adjusting screws??
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 12:10 AM   #31
bitchin85
bitchin85's Avatar
well with the old intake, i hooked a vacuum guage to it and backed each out till i got the best vacuum. thats the way i was told to do it and it seemed to work but im sure they are not the same for this intake
Old 03-08-2010, 12:18 AM   #32
54Caddy
GM Addicted
54Caddy's Avatar
i don't know about in your climate area but here in the valley in california i've always tighten the air fuel mixture screws all the way down and backed them out 2 full turns each and run them this way and have no problem. then from there adjust the idle screw down to where you like your idle i usually run mine low. also did you have this carb on your old intake with no problems?
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 12:22 AM   #33
bitchin85
bitchin85's Avatar
yea it ran pretty good on my old intake. could it be a weak fuel pump? maybe?
Old 03-08-2010, 12:25 AM   #34
54Caddy
GM Addicted
54Caddy's Avatar
fuel pressure can have alot to do with missing problems. hell go down and get a new pump and see how it runs a new pump should be less than 20 bucks. also how old is the coil in the dizzy the coil could be getting weak and not giving enough spark
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 12:27 AM   #35
bitchin85
bitchin85's Avatar
the coil is a year and a half or so old. it just seems weird that all this stuff is happening all at the same time then i change my intake. water pump goes bad.. missing, possible fuel pump and coil..
Old 03-08-2010, 12:35 AM   #36
54Caddy
GM Addicted
54Caddy's Avatar
yeah thats how these trucks get. Mine is the same way they require a lot of attention like another girl in you life ahahaha. mine does this too i replace one thing and another acts up but right now she's running good. but yea missing problems are a pain in the ass. could be fuel starvation and spark. the coil shouldn't be bad. also can have a problem with the ignition module in the dizzy the california shaped piece in there. those usually go out and wont let your truck start but can be. i say if the dizzy is acting up get one like i did from ebay damn thing looks good and works great.
http://cgi.ebay.com/ebaymotors/NEW-S...#ht_4195wt_968
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 12:37 AM   #37
bitchin85
bitchin85's Avatar
the ignition module is new.. idk if this means anythingbutit puffs a gas cloud out of the exhaust when its running.. its not oil its likeraw gas
Old 03-08-2010, 12:42 AM   #38
54Caddy
GM Addicted
54Caddy's Avatar
raw gas is running a rich condition that is unburned fuel. therefore the cylinders are getting to much fuel and it has to exit out some where. your mixture can be on the rich side. try adjusting the screws the way i said and see what it does.
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 12:45 AM   #39
bitchin85
bitchin85's Avatar
i remember when i was playlig with mya/f ratio, it seemed like no matter what i set them at, it still did that. could it be a weak/faulty coil? or is my plug gap too big? (.045)
Old 03-08-2010, 12:48 AM   #40
54Caddy
GM Addicted
54Caddy's Avatar
.45 is what i run mine at and it does fine. are you sure it fuel and not water? smoke can be a few things depending on what color it is. the coil can be weak if it was the spark wouldn't be an high enough amount of energy to combust all the fuel in the cylinders. also what style plugs are you running depending on them you can be running a hotter spark or a colder spark
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 12:52 AM   #41
bitchin85
bitchin85's Avatar
im running off the shelf accell u-groove header plugs. and i know its gas. you can smell it a mile aay and it gagsyou if itsbackedinto the garage and its running
Old 03-08-2010, 12:56 AM   #42
54Caddy
GM Addicted
54Caddy's Avatar
hahah make sure you don't close the garage door when running if its that bad ahahah. id first try the mixture screws than your fuel pump.
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 12:59 AM   #43
bitchin85
bitchin85's Avatar
lol not shut just backed into the garage with the door open lol. tomorow im going to findthe right timing tab somewhere and get my timing set and from there ill tweak my carb and ill see where that puts me. it if still misses i might just shove a rag in the gas tank and sit back and watch the fireworks.. lol jk but its frusterating when its your dd and you fix one thing and two other things break
Old 03-08-2010, 01:08 AM   #44
54Caddy
GM Addicted
54Caddy's Avatar
ahaha yup mine is my daily too. sucks when you get up at 5 in the morning and head to school and it breaks down damn things but oh well got to love them right?? kragen or autozone should have a little chrome one that works fine. timing is everything man, you can also get a fuel pressure gauge and run it inline just before the carb and see what it is at.
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 01:15 AM   #45
bitchin85
bitchin85's Avatar
yea it always brightens up my day... lol its been tore apart for 3 days too long now. just got everything dont tonight but still have to figure out why its missing.. tomorows another day.. shell out more money and pateince..
Old 03-08-2010, 01:17 AM   #46
54Caddy
GM Addicted
54Caddy's Avatar
hell yea i know that route i hate eating cup of noodles because the truck takes all my money hahaha damn college noodle diet ahaha.
..Mac’s Garage..
IG:MacsGarage
Old 03-08-2010, 01:19 AM   #47
bitchin85
bitchin85's Avatar
lol i hear ya.
Old 03-08-2010, 06:54 PM   #48
bitchin85
bitchin85's Avatar
timing problem... check
overheating problem... check
idle mix screws backed out two turns.. it still has a miss in one cylinder. i have the timing locked down at 8 degrees.
also ipulled my air cleaner off.. doesanyone know what this is? the white stuff? and the filter looks either burnt or melted or something.. itwasnt like this before i put the new intake on and it started missing..
Old 03-08-2010, 07:37 PM   #49
piecesparts
Parts and more parts
piecesparts's Avatar
It is very possible that you have a bad plug wire inside. I would locate the bad plug by pulling the wire off and see which one is missing. Then I would replace that wire with another to see if the miss goes away. I would also change out that plug.
Frank
piecesparts is offline   Reply With Quote
Old 03-08-2010, 09:00 PM   #50
54Caddy
GM Addicted
54Caddy's Avatar
alrite man like piecesparts said. The way ive done this is not the safest but you get use to a shock over now and then. Fire the engine up and have some one you trust put it in gear since this is when you have your problem. And start pulling a plug wire, if you pull say 1 off and it starts missing more then that 1 is not your problem then next go to 3 and when you pull this one off the missing stays the same. Bam 3 is the problem, you can do a resistance check on the spark plug wire too see if its good still or just inspect it for any cuts that would make it arc out. If the wire is good then inspect the plug maybe by accident that one didn't get gaped correctly or it has a lot of build up on it which would restrict the spark. Give it a try man. Good Luck!
..Mac’s Garage..
IG:MacsGarage
Thread Tools
Display Modes
