#26 |
Re: Truck Sits Crooked
If I was building a show perfect truck I would want to take the lean out... but just as a daily driver I don't see any reason to mess with it... especially if most other square bodies have it.
Does the front and back lean the same amount? The frame could be tweaked in one area and if only the front (or back) is leaning only way to fix it maybe by a frame shop. Offtopic... what kind of CB do you run?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#27 |
it's just a daily driver so I may be able to look into a frame shop see what they say. I think it actually leans on the whole drivers side I believe. I actually didn't get a CB yet I picked up the Antennas. I thought I had one lying around but I didn't. Any good ones you recommend. Jay
#28 |
I don't know what the hot CBs on the market are at the moment. I only have ones that others have given to me. I am currently running an Cobra 19 Ultra (original, I think they are on like IV of V by now).. but I do not like that it reverts to channel 9 every time you turn it off. I also have an old Realistic... I haven't tuned the SWR yet so I don't know what I am currently capable of. I am running a 102" whip on my Jeep Cherokee.
#29 |
102" thats big I want to get something that has a weather band built in I think that would be pretty cool. Reverting to channel 9 I think I had one that did that that's a accident waiting to happen..
#30 |
I would rather get into 2 meter HAM rather than spending a lot of money on a CB. You can get farther and deal with less BS with HAM.
#31 |
My truck is doing the same thing but since i lowered it the seems like it sticks when turning.i don't if its the ball joints are what.helpand thanks
#32 |
Yea I heard that they are alot better and farther. I wanted to set up a home station but never did. I was just at Walmart they have a Cobra with Weather band for like $60 bucks.
#33 |
So ok Guys what would you do leave the Lean or put back one of the old springs..?
#34 |
6.0 powered square
mines sits lower on the passenger side because of the gas tank
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#35 |
hey, my 85 swb has the same lean, i did L&R measurements and there is a lil more than 1 inch difference between the upper and lower arms. it leans to the drivers side. but i think its just my upper and lower arm bushings cuz they are rotted, and looks like the previous owner decided to just shim up the upper arm cuz theres about and 1.5inch of shims on the pass. side. and also my truck only has one gastank, so that could also be part of the problem.
been waiting for the bushing kit from Summit Racing, and just yesterday got a postcard saying the parts in back order and now i gotta wait till 3/31 so they can ship-it, thats if they can get it.. and i cant find any place here that has them in stock either. i will try an post up pics later today if this rain calms down. |
#36 | |
Redefining LowBudget
IF YOUR FRAME IS LEVEL its all in the badoy MOUNTS somewhere open the hood and measure from the top of the rad support to the ground in front of the rad on both sides....
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#37 |
Good point I looked at the A arm Bushings they look dry rotted I mean not horrible just hair cracks. Could the A Arm bushings be causing this. Or is it a chain of events maybe. Shimming up the Rad support is a good idea to.
#38 |
datguysaL do you have original springs I thought is was the springs I did the driver side spring and it leveled out but dipped to the passengers side when you brake cant win lol..lol.
#39 |
BAD BOW-Silverado XST
Torque!! Mine has the same problem. One inch difference between rear left and rear right height. Drives me nuts. I'll correct it soon enough with lowering leafs and spacer.
#40 |
yup, my truck still gots the stock springs up front and stock shocks. except for the shims the previous owner put on it.
#41 |
See if you got new springs and put the drivers side in it will level out lol. It don't solve the problem it bothers me.
#42 |
ima wait till the arm bushings come-in. and if that dont fix it, then ima keep on looking, i know theres got to be a way to fix the lean without having to shim up anything.
oh, yeah i forgot to metion that i can wiggle my lower drivers side control arm, thats why im blaming them for the lean. plus all the bushing are dry rotted and they have shrunk, i will post up some pics sometime next month when i get them and intall them. hopefully i dont get anymore postcards from summitracing. ![]() |
#43 |
Please do because my bushings are dry rotted also. If it fixes yours then I am going to order them I already have new springs thanks. Jay
#44 |
so finally i got the bushings in and installed both upper and lower a-arm bushings on both sides. while i was under there i also removed some of the shims the previous owner had piled on it.
once done, i remeasured, so now im just off by 1/4". not noticeable to others, but i see it, still gotta replace the shocks, and fix camber on my passangers side, so maybe thatll fix it... plus i still got all the body mounts to install, and trans mount, and leaf spring bushings, and find me a swaybar to intall on it also. Last edited by datguysaL; 04-09-2010 at 06:04 PM. |
#46 |
How hard was it to do the a arm bushings
#47 |
it wont be hard if u have the necessary tools,
what u will need to make it faster and easier, -pickle fork, or long prybar to pull spindle off arms -torch or somekind of flame to burn out the old bushings, mines i just heated them up with a regular propane heat flame. i pulled both the upper and lower control arms off the truck, i didnt wana risk burning up the truck when heating the old bushings up. on my old one the hole was way off center on whatever was left of the bushings. |
#48 |
with the new bushings how is the ride any diff. I did new springs well driver side lol. New shocks. It still feels a lil sloppy when you hit a bump do bushings affect the drive.?
#49 |
Badass
so have we found out how to fix the lean...mines front and back .in the drives side
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
#50 |
Gggrrr no mine leans driver side to still lol
Thread Tools | |
Display Modes | |
