Old 04-09-2010, 12:16 PM   #26
6D8_C10
6D8_C10's Avatar
Re: LS Engine Swap Question to the Collective
Originally Posted by thepunisher View Post
I'm stuck, so I figure I'll ask the collective for your opinions as to what everyone thinks. I want to swap the engine in my truck to a modern Gen III or Gen IV motor. The engine must have a manual throttle body because I am going to be using a 200-4R transmission. The two reasons for the 200-4R is I don't have to shorten the drive shaft, and I want stock gauges. I don't want a digital speedometer, and I don't what to run a digital to analog converter to make a electronic transmission work. Besides this would be a unique combination and I like that. I have a target of the engine making 400HP.
Hey, I ended up getting a LMQ out of a 99 Silverado that was running.
It is the 5.3L. But like you I didn't not want to try and convert everything to digital. I also am doing something that everyone thinks is going backwards. I am doing the edelbrock carb conversion. I bought the engine for $600 and the conversion for $600. So I am only in at $1200 because I all ready have everything else.
I am also using a rebuilt 200-4r trans because of the same reasons.
Remember the "L" engines have a flexplate that is dipped in the center so a older trans (th350, th400, 200-4r) torque conver center nose will not reach. So you have to get an adapter so that it can reach.
68 c10 350/th350 winter daily driver
90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver
"Just so we are reminded of those who are held back,
Up front there ought to be a Man in Black". Johnny Cash.
6D8_C10 is offline   Reply With Quote
Old 04-09-2010, 12:19 PM   #27
thepunisher
thepunisher's Avatar
6D8_C10 - Where did you get the adapter? Don't you have to use a different flex plate in addition to the adapter?
Blayne
thepunisher is offline   Reply With Quote
Old 04-09-2010, 12:22 PM   #28
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
a GenIII LQ4 is a good choice. You want to stay with a EFI truck intake in a truck because of the weight. Truck intakes make better torque w/o giving up too much top end. Going to the GenIV L92/LS3 style heads requires an intake change which if staying EFI is available(LY6,L92, and maybe L76?) and if going carb'd only single plane intakes are available. Not sure how the 200-4r TV cable hooks up to a cable style throttle body though.
I have a '09 LY6. It is the LQ4's replacement and has VVT along with L92 heads. I am removing the VVT and replacing with a high lift medium duration dual pattern cam, replacing the EFI intake with a carb style aluminum intake and using a Holley carb. Right now only single plane carb intakes are available from Edelbrock and GM, but GM is supposed to release a L92 style dual plane intake in about a month, thats been in the GMPP catalog for two years now. I am waiting for that intake. The build also includes a built(500+hp) 200-4r w/2500rpm stall converter.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-09-2010, 12:24 PM   #29
68GMCCustom
...and yes...there is an adapter (.400?) to run the "old style" transmissions available from GM.
Kurt -
Old 04-09-2010, 12:26 PM   #30
thepunisher
What kind of gas mileage would you get with a LQ4 and a carburetor?
Blayne
Old 04-09-2010, 12:37 PM   #31
6D8_C10
6D8_C10's Avatar
I meant to write LM7 not Q.
The carb conversion I got has a dual plane.
http://www.jegs.com/p/Edelbrock/Edel...55239/10002/-1
I got my adapter from Jegs also. Its made by Hughs.
You either need new flex plate or the adapter. NOT both.
http://www.jegs.com/i/Hughes+Perform...P3795/10002/-1
I haven't got it running yet, but I imagine it would get better MPG than a standard SBC.
The other thing about the carb conversion is the linkages to run the old trans is easier too.
Old 04-09-2010, 01:10 PM   #32
Shon
I got them for $35 shipped
And if you guys want quotes on the carb swap intake let me know. I am here for you guys!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 04-10-2010, 09:33 PM   #33
djw32
Will this adapter work with the 700R4?
Where did you get your adapter for $35?
djw32 is offline   Reply With Quote
Old 04-10-2010, 09:35 PM   #34
djw32
Do you know the part number for the flex plate?
Old 04-10-2010, 09:40 PM   #35
Shon
I do not see why not, I have them made for me, we use them in all of the swaps.
Just PM me if interested and I will give you the PP address.
Thread Tools
Display Modes
