Old 04-13-2010, 10:29 AM   #26
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: ls1 swap question
I have a Pierburg and you can bearly hear it running, it came with rubber jacket and it will easily feed my 4.8.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-13-2010, 11:31 AM   #27
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Originally Posted by 68fixeruper View Post
Omg lol that's terrible alright I'll just go 5/16s from the outlet of the pump and switch back to 3/8 before I get to the fuel rail. I just heard on the walbro pumps they don't last long so alot of ppl run the Bosch 044 because of realiability and it's quiet
Either one should last you a long time. I have had no trouble with the pump I've got and it's far from Walbro quality. I think most failed pumps are caused by cavitation, running without fuel and just low down abuse. Like no pre pump filter or pick up sock. Think about the pump in the tank of your late model car...running for years.
If your tank is under the bed then you'll probably mount your pump back there somewhere. Noise probably won't be an issue. My truck's 43 years old. There's nothing quiet about it and I'm okay with that.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 04-15-2010, 07:37 PM   #28
68fixeruper
68fixeruper's Avatar
so i went to napa today and found this pump im just curious if u guys think it will work
http://www.napaonline.com/Search/Det...00_0249673437#
68fixeruper is offline   Reply With Quote
Old 04-16-2010, 12:29 AM   #29
stevencvn72
Kill Bill...et
Looks like that one should work. Anything over 30GPH should be good. As long as it's American made. Here's a couple of websites that'll help you out with your LS1 Swap. The first site is for the TPI 305 swap and a little slow to navigate thru but when you get a chance to read it, there's a lot of good info.
http://chevythunder.com
http://www.fuelinjection.com/portinj.html
-Steve
I Grease
'67 Chev stepper
Old 04-16-2010, 12:32 AM   #30
stevencvn72
Kill Bill...et
Lightbulb Re: ls1 swap question
A fuel pressure gauge for your engine bay wouldn't be a bad idea either since you're already running fuel lines. Good for troubleshooting and tuning later down the road.
-Steve
I Grease
'67 Chev stepper
Old 04-16-2010, 12:43 AM   #31
5150.4.67
Speedway also sells stainless. Its hard stuff! It's bullet proof however. You need a really stout flair tool to make it work. Some guys use copper flare washers in between the flares, I've seen others use compression AN- fittings as well. Make sure that aluminum line does not even THINK about touching anything without a rubber isolator. It will wear a hole through the line in no time. I'm speaking from experience.
My $.02? Stay away from aluminum.
5150.4.67 is offline   Reply With Quote
Old 04-16-2010, 06:10 AM   #32
skoffice
skoffice's Avatar
I'm running the aluminum hard line for mine. It's not too bad, you can actually do a lot of the bending with your hands. It's easy to flare and the fittings are dirt cheap. If I were to do it again though I'd probably run push-lok. Not as fancy or durable as a metal or braided line but dam that stuff is just too easy, and good to 250 psi. As for a pump I'm runnin an Aeromotive but the dam thing cost an arm and a leg. Nice and quiet pumps though. I hear a lot of good things about the Walbro pumps, seem to last forever and deliver plenty of fuel but I haven't witnessed the noise factor myself.
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Thread Tools
Display Modes
