Old 10-26-2011, 02:27 PM   #26
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: GMC guys! Dana 44 ??
I have a power lok Dana 44 in my 67 GMC 4x4. Will refer to this thread when I get to restoring it. Good info here
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 10-27-2011, 11:25 AM   #27
steinepstein
I also just measured the bolt dimensions on the axle housing end. They are the same as a big ford housing end. 3.5" x 2.375". You can find these dimensions on the assembly instructions document on the Wilwood website. Wilwood brake set 140-7139 should bolt right up to that housing end. I still need to confirm the bearing offset, I think that may have to be changed or find a brake kit with a different offset.
Saved myself a rearend without tearing it up.
Good stuff.
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216
steinepstein is offline   Reply With Quote
Old 10-27-2011, 12:19 PM   #28
steinepstein
Ok, I just confirmed that the axle pilot hole will have to be turned down to fit the 140-7139 Wilwood kit, but other than that, the axle housing end and bearing on the Dana 44 is big a Ford 9" setup, awesome. Captain Fab also mentions turning down the axle pilot on some of his brake kits (I didn't quite understand at first). Anyway good luck with your setup, I'm glad you got this all posted in the first place, saved me a bunch of time and money.
Old 10-28-2011, 01:28 PM   #29
fasttech
fasttech's Avatar
I will depend on the rotors you are using. I am using 1980 Seville rotors which require the center pilot to be turned down as well as the outer part of wheel flange. Then if you are changing from a 6 lug to a 5 that machine work has to be done.
fasttech is offline   Reply With Quote
Old 02-02-2013, 08:35 AM   #30
ivanuf2
ivanuf2's Avatar
Anyone finally did the 44 Dana disk brakes, or can confirm the Wilwood kit part number that will fit the Dana with the big ford axle?
ivanuf2 is offline   Reply With Quote
Old 02-03-2013, 11:40 AM   #31
fasttech
fasttech's Avatar
The setup I am using works but I can't comment on the Willwood.
If you want to go the build your own route here is what you need:
* Ford 9" Bracket Kit (from Oldedays)
* Left Rear Caliper GM 79-85 (Cardone 18-4139) this one has the parking brake
* Right Rear Caliper GM 79-85 (Cardone 18-4139) this one has the parking brake
* Brake pads for GM 79-85 rear caliper
* 1978 Seville Rear Rotors (can get get slotted and drilled as option)
* Disc Brake Hose Kit (Gear Head 9828) this one is stainless
* Parking brake cable (BrakeBest BC93292) needs a little customization
* Get axles turned for a 3" pilot and outer flange diameter of 6.125" or just have some new axles built like I did. When I compared the cost of all the machine work (including 6 to 5 lug) to the cost of new ones it was only about $100 more. Got mine from Dutchman Motorsports.
Old 10-28-2023, 02:04 AM   #32
Chuck78
Great old post, adding some additional info for the 60-72 GMC Dana 44 1/2 ton owners looking to do a 5-lug disc brake conversion, NITRO CUT-TO-LENGTH CHROMOLY DANA 44 30-SPLINE JEEP AXLES!
https://nitro-gear.com/nitro-gear-ax...1971-2018.html
https://justdifferentials.com/nitro-...r-dana-44.html
Triple drilled including 5 on 5" lug pattern, 5 on 5.5", & 5 on 4.5"!
This doesn't help the 6-lug guys, but for me, this seals the deal on whether or not swapping a 75-91 5-lug 2wd disc brake Suburban front suspension crossmember was a good idea or not...
Chuck in Ohio
*1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end
*1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project
*Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc
Chuck78 is offline   Reply With Quote
Thread Tools
Display Modes
