Old 03-22-2011, 11:10 PM   #26
richards72chevy
richards72chevy's Avatar
Re: High Mileage Turbo 350 Filter Change.
I never heard about this before.Maybe in some other make of vehicle.I have heard that overdrives go out faster if they are driven under 65 mph alot.
richards72chevy is offline   Reply With Quote
Old 03-22-2011, 11:25 PM   #27
benoit454
Chris
benoit454's Avatar
the reason OD's go out faster under 65 is ppl put them in od and drive around town in them stop and go never getting to highway speeds and such, I ALWAYS heard it was bad to do that, not sure how true it is but I always heard to drive around town in drive and not overdrive.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 03-23-2011, 11:00 AM   #28
05crewcab
05crewcab's Avatar
It is true, but it also depends on your trans. This happened to my dad's 91 with a 700R4. The reason they wear out is the transmission constantly hunts between 3rd and overdrive if your speed fluctuates between 40 and 55 mph. That constant in and out causes a lot of wear on your OD. You are better off keeping it in D until you hit highway speeds.
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 07-28-2011, 10:03 AM   #29
CEE1NG_RED
...WHEN dropping the trans. pan, will I need to remove the entire ATF before pouring in new trans fluid? I just want to fix the leak caused by the RTV on the pan and replace it with a rubber gasket and change the filter. Will it hurt the transmission if I do it that way (Just refill the trans. with new ATF that is mixed with the previous ATF). The PO I believe put Dot 3, BUT I'm just adding ATF DexMerc, which meets Dot 3 specs as well. PLEASE let me know if this will be fine? I will be doing this after work today. [sigh]
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 07-29-2011, 12:01 AM   #30
Captainfab
60-66 Nut
Ummm, DOT 3 is brake fluid. If you just replace the ATF that you drain out with new DexMerc ATF you will be fine.
Old 08-01-2011, 03:56 AM   #31
CEE1NG_RED
...DONE! Thank you.
BTW, when checking for ATF level w/ the dipstick, it is on full (near the top line mark) when it has not been turned on. When it's running and on idle, it's on the minimum mark (asking that it needs 1 quart more). What gives?? LOL
Old 08-01-2011, 04:23 AM   #32
COBALT
COBALT's Avatar
Don't bother checking your transmission fluid with the truck NOT running and cold. The ONLY way to check it is at normal operating temp (you want that fluid hot), and the engine running. Whenever I get the itch to check it I drive it around for a while, then go somewhere where I know I'm on level ground, shift through all the gears, then put it in park, and while the engine is running check the fluid. It should be up to the hot full mark. If it's not add just enough to reach the line. Not more.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-01-2011, 05:37 AM   #33
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
i have a high millage transmission half million miles on original transmission last fluid change was about 120000miles before i got it, in my volvo the fluid was black almost looked like the stuff that comes out of diesel engine.
i changed the oil and filter, never shifted better and i have put 30000miles on it. we do this on a regular bases at the shop im at and never had a problem
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Thread Tools
Display Modes
