11-23-2010, 12:36 AM | #26 |
Re: Parting 3/4ton 2wd Big Block Truck
do you have to tail light bezels? pics??
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
11-23-2010, 02:38 AM | #27 |
Harold- I will check on switches and wire. I might have some ac screws in the hardware bin.
Adam- $68 shipped on the high hump...I have cheaper ones with holes in them. Youngbuck- Sorry, no good bezels. Thanks, Ray |
11-23-2010, 03:41 PM | #28 |
Are the lower a arms the same as 67? If yes im intrested in them for lifting my 67 c10. do you have any of the other lift parts (88 lift spindals etc..).
Thanks Ed |
11-23-2010, 04:09 PM | #29 |
Formerly- 1972SuperCheyenne
I would be interested in a high hump cover as well as the floor section it bolts to so I can convert my small hump cab if thats possible.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
11-23-2010, 06:43 PM | #30 |
"Junkyard Dog"
Any intersest in selling the valve covers? Are they original GM? I have a pair of nos M/T's. Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
11-24-2010, 12:15 AM | #31 |
Harold- $15 shipped on the switches, wire, screws.
1972SuperCheyenne- 2nd in line on high hump tll74- I have stock BB valve covers $35 shipped |
11-24-2010, 01:21 AM | #32 |
"Junkyard Dog"
Are these a match to the chrome covers (loom holders, wire holders etc.) Trying to find the correct covers for a 1970. Thanks
11-24-2010, 01:34 AM | #33 |
I will check Wed. I believe they came off a 71...but that was almost 20 years ago when they were pulled.
11-24-2010, 10:14 PM | #34 |
ray how do want to be paid? I can do paypal now. Sending pm thanks Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-24-2010, 10:29 PM | #35 |
11-24-2010, 10:31 PM | #36 |
11-24-2010, 10:42 PM | #37 |
pics
11-24-2010, 10:46 PM | #38 |
There is one cut wire on the kickdown.
11-25-2010, 12:05 AM | #39 |
"Junkyard Dog"
I'll do some research to find out. Is the engine still available? Thanks
11-25-2010, 03:09 AM | #40 |
11-25-2010, 08:32 AM | #41 |
55454
Do you have the passenger side under cab exhaust hanger?
Thanks Tommy
72 Cheyenne 1956 3100 1955 210 19 year old Chihuahua (Factory Teeth) |
11-25-2010, 11:02 AM | #42 |
Can you post some pics of them?Thanks Tony
1991 GMC K2500 4X4 350/auto 1991 Chevy S10 ext cab. 1990 Chevy S10 1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto |
11-26-2010, 12:38 AM | #43 |
"Junkyard Dog"
Ray,
What does the engine come with? Such as carb, dist, ex.manifolds, flywheel, mounts, pulleys, water pump, etc. Thanks
11-26-2010, 12:58 AM | #44 |
55454- sorry, no hanger
tanman- will get pics, but they look bad and the pitting shows through tll74- long block with intake, flywheel, dist., water pump, and valve covers Thanks, Ray |
11-26-2010, 01:52 AM | #45 |
"Junkyard Dog"
Hmmm....ok..so it would have the balancer, t-cover, water pump, flywheel, intake, dist w/wires, valve covers, coil, thermostat housing, and p/b vac line. Do both valve covers have the loom holder brackets for the four wire holders? (located on the inside towards the rear) Is it possible to get the stamped info off the block in front of the RH cly. head and the block cast number located LH near bell housing?
11-26-2010, 09:48 AM | #46 | |
Thanks, Ray |
11-26-2010, 10:23 AM | #47 |
"brand new second-hand"
interested in the "396" emblems are they in good shape? how much shipped to 91739 please......thanks Steve
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
11-26-2010, 12:43 PM | #48 |
11-26-2010, 02:35 PM | #49 |
Pics of High Hump. There are approx. 5 screw holes (see pics) and residual glue from the carpet. Other than that, it is in great shape.
11-29-2010, 10:35 AM | #50 |
Thread Tools | |
Display Modes | |
