02-23-2011, 09:47 PM | #26 |
Grandpa in the rustmobile...
Re: Rattle Can Green: Opinions
Im REALLY considering it.
I found a baby blue rustoleum that matches my truck really well, if you look closely, where the 67 68 trim went, there was the OEM med. blue, I washed the truck and rattle caned it, you can barely tell from 10 ft
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-24-2011, 02:54 PM | #27 |
That looks sweet!
1968 Chevy C10: 4x4 conversion, 6" lift, 37" GoodYear Military OZ's, carb'd GMPP RamJet 350, Be Cool aluminum radiator, Flex-o-Lite electric fans, March accessory brackets, T350 trans, NP205, 4 wheel disc, fuel cell... etc. |
02-24-2011, 05:09 PM | #28 |
[ATTACH][/ATTACH]
not a c-10 but my old truck was sportn the flat olive n white.... |
02-24-2011, 06:06 PM | #29 | |
Also back to main topic..truck looks good just prep the rest how you feel best and finish..Good job |
02-24-2011, 06:22 PM | #30 |
My truck is Olive Drab "rattle can". Most people think it's primer. It'll do until I can save up for paint.
Check out my album!:http://67-72chevytrucks.com/gallery/...y.php?cat=1263 The beatings will continue until morale improves. |
02-26-2015, 09:08 PM | #31 |
were do you paint it to keep debris out of it? and how many coats did you put on?
02-26-2015, 09:47 PM | #32 |
US Army Veteran
Rattle can spray dries in minutes. Still, you could always head to a local car wash and use one of the empty bays, or under the bay where the vacuum canisters are.
For an even more interesting adventure, pull into a Sonic and paint it there!
1972 C10 Highlander - The making of a daily driver |
02-26-2015, 09:50 PM | #33 |
wow i think i would be banned from sonic if i did that. I'm in houston so the car wash is too crowded. i used to paint guitars and if i did it outside it always ended up with dirt ir pieces of leafs in it. theres a parking lot near my house with a fence on one side and a building on the other. maybe there will block the wind.
02-26-2015, 10:40 PM | #34 |
got me thinking about this rattle can idea. my truck is three different colors. I wonder if you want to get a professional paint job later on would this make it more difficult to paint or more expensive.? looks like a flat or semi gloss would work best. Lowes has a large selection of spray paint. going to check it out tomorrow.
02-26-2015, 11:09 PM | #35 |
$3.50 a can?!??
I go down to Rodda industrial paint and have them mix me up a gallon of their finest, any color I want, flat or shiny, and they color match. $22 for the paint and another $20 for the xylene Forty two bucks and I have enough to spray at least two trucks. |
02-27-2015, 12:34 PM | #36 |
Some rattle can spray dries in minutes. We have been using some Rustoleum Semi-Flat black at work that takes forever to dry. The Krylon 1613 Semi-Flat black is dry to a touch in minutes. But, it goes on much thinner than the Rustoleum.
Thread Tools | |
Display Modes | |
