Old 06-21-2011, 10:23 AM   #26
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Holley Carb.
Hope you get this figured out Nigel....so what did ya use to clean up the carb??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-21-2011, 10:25 AM   #27
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Holley Carb.
That is a somewhat newer Holley 750 with the zinc coating. Holley hasn't been using the gold anodized boosters all that long.
What size motor is that on? That's a pretty good size carb.
prostreetC-10 is offline   Reply With Quote
Old 06-21-2011, 10:37 AM   #28
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Holley Carb.
I should do Geoff, I used Autosol chrome polish and that stuff that's free..elbow grease a toothbrush was a good tool for all the nooks & cranny's, I even polished that ugly white wire and trimmed it, now it's less obvious and looks kinda part of it.
I would have liked to be able to keep the gold cadmium plate look of all the brackets and levers etc, but most of it was badly tarnished and if you try and clean it the cad plate comes off.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 06-21-2011, 10:45 AM   #29
eightbanger
454 MAKES IT ROAR
Re: Holley Carb.
454...I reckon whoever did all the upgrades on this truck back in the states did it some time ago and did it pretty well.
Nigel.
No more pain.
Old 06-21-2011, 10:59 AM   #30
prostreetC-10
My Carbon Footprint
Re: Holley Carb.
Ah....the dreaded 454! lol I think I have 3 or 4 of them in vehicles around my place. Those 3310s to work nicely on a warmed up '54.
Old 06-21-2011, 12:57 PM   #31
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Holley Carb.
Here is the choke side of my 3310. I removed all the junk there, but had to reuse the bracket you see held on with the 3 screws (blue circle). It covers a small port that needs to stay plugged. I also just reinstalled the big phillips head screw (red circle) back into the throttle shaft to make it look a little cleaner.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-21-2011, 01:40 PM   #32
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Holley Carb.
Sure does look awesome Nigel....this will be added to my winter project!!!
Geoff with a G
Old 06-21-2011, 02:34 PM   #33
prostreetC-10
My Carbon Footprint
Re: Holley Carb.
Gary
Yes, you had to do that because this carb has the internal vacuum source. I usually tap that hole with a 6-13 thread and run a set screw down it. This was you can just unscrew it if you want to run an electric choke.
On my T-ram, I have the lower fast idle portion hooked up to the front carb. I have both flaps removed and the fast idle portion of the second carb gone. Since the carb linkage is sync'd, having the fast idle on the front carb affects both carbs. I just stick my hand under the Hilborn and pull it back to taste. As she builds temp I just keep backing 'er down until it will idle on its own. Works great for me and I don't have the cable running into the cab.
Old 06-21-2011, 02:39 PM   #34
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Holley Carb.
nice idle adjuster tool under that carb LOL
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-21-2011, 02:47 PM   #35
prostreetC-10
My Carbon Footprint
Re: Holley Carb.
Are you talking about the secondary shaft kit? They are nice but not needed on a NON 4 corner idle carb.
Thread Tools
Display Modes
