Old 09-03-2020, 08:39 AM   #26
72LB
72LB's Avatar
Re: Changing dash lights to LED's with stock gauges?
Originally Posted by Rich72C10 View Post
Hi guys - I am looking for LEDs for my dash gauges/cluster/indicators. So I have this correct for this setup? My truck is still at my brothers for a engine rebuild but want to start stocking up on parts for things I want to do when it returns (soon I hope).
4 - White (gauges)
2 - Green (turn lights) or is getting a green LED not really required?
1 - Blue (high beams) or is getting a blue LED not really required?
Perhaps I should not get "4 point/SMD" for Turns/High Beam indicators?
No Reds since I have gauges for temp, oil, amps???
Does the Gear selector have a light? I cannot seem to recall. NM, its some fiber wire thing for non-tilt columns.
What are the bulb type number in the stock Heater/AC controls?
The blue light your wanting for you high beams is going to make it purple as the high bean spot has a red filter on it.
The gear selector is fiber optic and runs off one of the dash bulbs.
The heat/ac control is a 1895 bulb.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 09-03-2020, 08:44 AM   #27
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Thank you 72B - so just stay with a White is what you are recommending as the OEM filter will take care of the blue color? I'd assume that would be the same for the turns too?
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 09-03-2020, 08:46 AM   #28
72LB
72LB's Avatar
Do you mind telling me what the LEDs (site/part numbers) you used, did they advertise "dimming" or the voltage range?
I got the led's from this guy on Ebay https://www.ebay.com/usr/jtechnowcom...88.m1543.l2754
They aren't dimmable as most aren't. I did look at whiteguages.net but at the time I wasn't going to spend 20 bucks a bulb, I plan on changing the dash soon.
I would just put white behind them.
Old 09-03-2020, 08:56 AM   #29
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Again, thank you for your information. Yes, $20 per light is a bit much but the lights @ http://www.whitegauges.net/ are now $5.
Your information is very helpful, I think I'll get 4 of the 194-WHITE from whitegauges (dimmable). And '90 degree whites for the turns/high beam indicators (non-dimmable)
BTW, might you know if the inside dome light is also 1895 bulb?
Richard
Old 09-03-2020, 09:01 AM   #30
72LB
72LB's Avatar
I noticed they were 5 bucks now, figures lol.
This is the dome light I have in mine https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have a clear lense cover and it's real bright.
Old 09-03-2020, 09:14 AM   #31
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Nice, glad I asked! While I am still noodling on this, this is what I think I'll be going with.
7 - Gauge Lighting: 194-WHITE from whitegauges (dimmable 6v~12v)
1 - Dome Light: DE3022 CAN Bus LED Bulb from superbrightleds.com
2 - Heater/AC: BA9SF-W-12VAC LED Landscape Light Bulb from superbrightleds.com
Richard
Old 09-03-2020, 09:21 AM   #32
72LB
72LB's Avatar
Looks good. Hope the dimmable part works for you, keep us posted.
Old 09-03-2020, 09:24 AM   #33
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I will do, though I'm hoping to have the truck back in Oct or so... so it would be a while before I'll have results.
Richard
Old 09-03-2020, 04:15 PM   #34
Metaldoc
Metaldoc's Avatar
all white LED's
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Thread Tools
Display Modes
