Old 09-12-2011, 05:27 PM   #26
lil hoodlum
lil hoodlum's Avatar
Re: 69 gmc needs started no spark
Originally Posted by pbro View Post
What are your guys thoughts on this, taking the dizzy out and placing it in a vice, supply it with power and hooking it up to a drill. I then use a spark plug wire to see if it sparks? Any concerns?
Why not just leave the distributor in the engine and pull one of the sparkplug wires off of a sparkplug and hold the sparkplug wire with a pair of insulated pliers within a 1/4 or less to the sparkplug. What you are looking for is a blue arc of electricity the closes the gap between the sparkplug wire and sparkplug. If it is working correctly, it will fire when the rotor hits that portion of the cap of the sparkplug wire you are holding. Yes, someone else should be trying to start the motor so that the rotor is moving.
Please please use an insulated tool to hold the sparkplug wire. I would hate for you to get a jolt if it is working correctly.
If you get no spark, you know the problem is the distributor and/or wiring up of the distributor.
Good luck,
Keith
lil hoodlum is offline   Reply With Quote
Old 09-25-2011, 03:01 PM   #27
pbro
So you guys know I replaced everything from the coil, cap, rotor, capacitor, and had the ignition checked. I got tired of the nickel and dime in parts that I researched the forums and bought an inexpensive dizzy from skip white on eBay.
Put it in today, first crank it turned over and ran like a champ. I love this stuff.
Thanks for all of the input and suggestions.
pbro is offline   Reply With Quote
Old 09-25-2011, 06:02 PM   #28
lil hoodlum
Hey congratulations! So what's next on the agenda?
Keith
Old 09-25-2011, 11:27 PM   #29
pbro
got the drive shaft in and will take it for a ride soon. Might get that cab
Thread Tools
Display Modes
