Old 10-24-2011, 05:52 PM   #26
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
Re: What did you get done 10/23/2011 thread
Put on a shine and put my stock gauges back in for looks i have aftermarket ones which i use
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 10-24-2011, 07:07 PM   #27
Buzzman
Buzzman's Avatar
Replaced the driver's-side header gasket (still ticking - I give up!). Washed inside and out - probably the last one of the year. Tried in vain to lube up my sticky gas pedal/throttle linkage... got fed up, started drinking.
79 C10 Cheyenne SWB Daily Driver
Buzzman is offline   Reply With Quote
Old 10-25-2011, 12:12 AM   #28
BigRed76
BigRed76's Avatar
I replaced the rear main seal, oil pan gasket, front crank seal, timing cover gasket and water pump gasket. Also got the new 4 row aluminum radiator put in. Hopefully now there will be no more leaks for a while
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 10-25-2011, 09:45 PM   #29
motornut
78K & 79C Jimmys
motornut's Avatar
watched it rain....
ran out did the fuel pump....then rain
tried bending the line from the pump to the carb twice,
snapped the handle, then snapped the rivit in the middle.....musta needed a new one
changed wires.....then rain
checked plugs.....more rain
went to start the 79 jimmy,had flat dual batts
took out the 79 cluster....in the rain
went out to move the 88 burb and it's batt was flat
and thats after the 78 Jimmy's batt goin flat after taking out the inner fenders?
so i got 4 flat batts in about 2 weeks.....that time of the year
all four getting charged to try again lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Thread Tools
Display Modes
