01-25-2012, 03:39 AM | #26 |
In the Forgotten far North.
Re: Does Changing Firing Order make more Power?
always remember.... There is no such thing as a stupid question.....
. . .. . . . . . . . .only UNINQUISITIVE IDIOTS!!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
01-25-2012, 08:35 AM | #27 |
You can't fix stupid. Dumb on the other hand is teachable. That's what I figured this forum was for.
01-25-2012, 10:44 AM | #28 |
which makes it run smoother
01-25-2012, 11:15 AM | #29 | ||
Incorrect sir because you chose to ignore the next sentence that I wrote...
1 5 2 1 3 6 4 2 5 7 6 3 7 8 8 4 1-8-7-2-6-5-4-3 LS/LQ Firing order 1-3-7-2-6-5-4-8 Ford 351 Firing order Now if you start both engine on the same cylinder the Ford Firing order becomes 5-4-8-1-3-7-2-6 Oh looky it is the same sequence as the LS. BTW that diagram does not give the whole issue, you must go throught the whole firing order not just half.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." Last edited by 406 Q-ship; 01-25-2012 at 11:35 AM. |
01-25-2012, 12:37 PM | #30 |
The person that put this thread up was not stupid, or dumb. He was ignorant. Ignorant means= lacking knowledge, information,or awareness about something in particular. The person that said he was stupid is not stupid. He is ignorant. He is also a mean person. People who dis respect people should be kicked off the site.
01-25-2012, 01:09 PM | #31 | |
01-25-2012, 01:48 PM | #32 |
There was a pretty extensive article in, IIRC, Car Craft mag a few months ago regarding the hows and whys of the LS firing order change. In so few words the change was made to reduce NVH (noise, harshness, vibration).
In other news, in the early EARLY days of NASCAR engine builders would reverse the rotation of the engine to change the torque loading of the chassis in the turns. |
01-25-2012, 04:32 PM | #33 | |
A little know fact is that the Cadillac 472-500-425-368 use the LS firing order. The Cadillac 472 was introduced in 1968. The Ford 351W was introduced in 1969. GM used the firing order before Ford did. I've also read that the head design of the LS motor is loosely based on the Cadillac V8 as well. GM actually did get it right!
1977 GMC Sierra Grande |
01-25-2012, 08:40 PM | #34 |
Believe it or not firing order can be changed. Not to the 1 2 3 4 5 6 7 8 but it can be changed. I.e. marine engines. There are several modifications to marine engines one of which includes a change in firing order and the direction of which the motor is turning. I also dabled in Fords. I put a 351 windsor cam in a 302. It all works but the firing order is different between the two motors. Really pissed of the next mechanic that worked on the motor too He couldn't get that thing fired up for nothing using the 302 firing orfer.
01-25-2012, 09:07 PM | #35 |
I have a short stroke Merlin 3 572" race motor for my offshore boat that has a 4/7 swap. The cam guy insisted on it and cited "harmonics" over my likelihood of screwing thing up when tuning... I was just writing the check and turning wrenches though. I've never seen the spintron footage at any of that crap. I just try to keep the rods in the inside and me on the outside...
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
01-25-2012, 09:12 PM | #36 |
here's a link with several pages on the subject
http://www.speedtalk.com/forum/viewt...2ef81e0fd5b562 |
01-25-2012, 09:52 PM | #37 | |
01-26-2012, 12:50 AM | #38 |
How to become less ignorant......... the following was the best answer givin by Yahoo.
That is an excellent question, how to be less ignorant. At least you know you might be ignorant - it is worse to be ignorant, and not know! Firstly, don't ever be afraid to ask other people questions. I mean, in the real world, especially people older than you. That's a major way of learning. I recommend starting a program of learning by reading your local newspaper as often as possible. You will be introduced to an enormous amount of different issues. At first, many issues may seem difficult to follow. But, as you build more and more knowledge, your learning will become faster, and more pleasurable. If you are a curious person, the things you will discover from reading a good newspaper will lead to you later going after more specialist knowledge in books, etc Well I guess were all ignorant about something....every last one of us
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
01-26-2012, 09:12 AM | #39 |
The top sportsman engine builder in the country was asked the reasons he installs 4/7 swaps in his customer's engines.
"Because they expect it" was his answer. It may pick up a couple of foot lbs of torque, but not much more than that. It may run a bit smoother, but bearings look the same at tear-down with either cam. |
01-26-2012, 12:24 PM | #40 | ||
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
01-26-2012, 02:02 PM | #41 |
Keep in mind that you're limited in what you can do by the configuration of the crankshaft...you can't fire a cylinder when the crank is on the intake stroke!
01-26-2012, 03:03 PM | #42 |
Arrived on a Pale Horse
I've seen it done, but not with good results.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
01-26-2012, 03:22 PM | #43 |
^ yeah, it's surprising that one will even fire with the dizzy 180* out, but it will.
And really makes you feel stupid when you figure out what the problem is |
Thread Tools | |
Display Modes | |
