Old 05-08-2012, 05:42 PM   #26
FAT TONY
FAT TONY's Avatar
Re: 64 c10 help?
thanks bill...... well what is required to open up the differential? ...... fluid drainage ? and to put it back together would i need a new gasket and some new lubricant liquid? and help is appreciated... it would be my first time doing it so if there is a step by step tutorial in the site on how to do it would really help also
"So she said, "Either I go or the truck goes!"....Hmm, I wonder what she's doing these days?"
FAT TONY is offline   Reply With Quote
Old 05-08-2012, 06:36 PM   #27
billd5string
billd5string's Avatar
Re: 64 c10 help?
It depends on what kind of diff you have, but a standard 10 or 12 bolt rearend just requires pulling off the inspection cover (diff cover) and counting the teeth on both the ring gear and the pinion gear.
The covers don't always have a drain plug, so once you loosten those bolts, fluid spills out everywhere. Some of the gaskets for these covers may not be readily available, so I would get one in hand first before pulling it apart. And lastly, I'm not sure you can even see the pinion gears to count them without also pulling out the differential itself.
Frankly, I personally wouldn't go down that path because it isn't really that useful of information to know exactly which gear ratio you have. The difference between a 3.42 and a 3.73 isn't enough to warrant all that extra work. Counting the revolutions of the driveshaft or tire will get you close enough.
Good luck with whichever you decide to do.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 05-08-2012, 07:09 PM   #28
oem4me
Re: 64 c10 help?
Put chalk marks on your drive shaft and tire and watch them closely. if the shaft turns like 4 1/2 times per one rotation of the tire as opposed to 3 3/4, then just maybe your gear ratio is part of the issue.
Old 05-09-2012, 12:31 AM   #29
FAT TONY
FAT TONY's Avatar
Re: 64 c10 help?
ok thanks for the help, i will try to check it this weekend
Thread Tools
Display Modes
