Old 01-05-2016, 01:07 AM   #26
Ol red 71
Re: 1971 LED Turn signal's
So that's an electronic flasher with a ground. Did you use a reverse polarity adapter with it? Did you use another electronic flasher for your hazard lights also? Thank you for the pic
Ol red 71 is offline   Reply With Quote
Old 01-05-2016, 01:34 AM   #27
Ol red 71
Thumbs up Re: 1971 LED Turn signal's
I just checked out the thread you posted for me. Since the led parking lights are a three wire setup that means I have to make a ground out of one of the three wires since my truck is a two wire setup? Makes perfect since. I'll also need to install electronic flashers. Please let me know if I am incorrect in what I've said. Obliged!
Old 01-05-2016, 11:43 AM   #28
Andy4639
Old member
Andy4639's Avatar
Correct the factory wiring is 2 wires so yes you will need to figure out which is ground for the LED's.
Yes I used both electric flashers for both.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-05-2016, 11:19 PM   #29
Ol red 71
I cannot thank you enough for this information. Last question; is it necessary to ground both parking lights or just one?
Old 01-06-2016, 06:42 PM   #30
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: 1971 LED Turn signal's
I would think both would have to be grounded.
Thread Tools
Display Modes
