08-16-2012, 10:27 PM | #26 | |
Re: Brake problem...frustrated
Still the same? Crack the line at the Master Cylinder...If it now goes down....The proportioning valve not centered/stuck/rusted. Still the same? Bad master, Master not bled, Air in the lines. |
08-16-2012, 11:09 PM | #27 | |
Thanks |
08-16-2012, 11:53 PM | #28 | |
I would do as clinebarger suggested. Start at the master, cracking lines open then move down the line until you find the point of restriction. MC pistons can stick, rubber hoses can swell shut, metal lines can be crushed, etc.
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
08-17-2012, 12:27 AM | #29 | |
Thanks |
08-18-2012, 09:46 AM | #30 |
Front bleeding: pedal goes to floor...rear bleeding: pedal does not go down much but fluid does come out. ?????
08-18-2012, 10:19 AM | #31 |
Just a car guy
Is fluid running out the rear, or spraying with pressure?
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
08-18-2012, 10:25 AM | #32 |
You have to open a front bleeder and stomp on the brake pedal real hard, The sudden loss of front brake pressure will trip the prop valve. You may have to do this 2 or three times depending on how stuck the valve is.
08-18-2012, 10:42 AM | #33 |
I did this with mine a bunch of times (trying front, then rear) and the darn thing never did free up.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
08-19-2012, 09:03 AM | #34 |
08-19-2012, 09:32 AM | #35 |
It certainly couldn't hurt to change it if you have an extra. That would eliminate it as a possible source of the problem.
08-20-2012, 07:36 AM | #36 |
As far as the system not stopping well, I have the same problem with my new booster. I asked this question a few months ago and got this answer: . . . . |
08-20-2012, 08:18 AM | #37 |
Just a car guy
Check pushrod as above.
Also, bleed bleed bleed. When I got my new brakes done, it seemed like I had to bleed forever. I bet I filled the resevoir 6 times or more. Finally the fuild out the rear went from a steady stream, to a pressure blast! Posted via Mobile Device
08-20-2012, 08:20 AM | #38 |
Just a car guy
Just thought, in regards to the pushrod, how does it do when you bleed the fronts? Does the pedal go down? Does the fluid come out at higher pressure then the rear?
08-20-2012, 10:03 AM | #39 |
Seems to come out well in the rear but even better in front. The pedal will not go down to the floor when you open the rear bleeders though.
08-20-2012, 12:33 PM | #40 |
I left it alone. I have another one now that I'm trying to figure out if it's good or not.
08-20-2012, 12:38 PM | #41 | |
08-21-2012, 09:33 AM | #42 |
Again, my brakes slowed the truck to a stop. I checked the push rod clearence and as Longhorn Man said "That's not problem", but I did it anyway. I just installed the hydrailic booster and now the stop comes to a quick stop. LOL
Thread Tools | |
Display Modes | |
